Label Stock Wrinkles on KMC1060
  • OverKnight
    • Sep 2019
    • 55
    Same machine, different issue... or same issue that is the cause of everything. LOL
    In the images I uploaded, there is a defect in the paper created before entering the fuser. Coincidently, I just replaced the fuser belt and the problem became chronic. The stock is 11" x 17", 60lb. gloss label with a 80# liner. Tray 4 is set for 217-256 GSM and this is the primary workload for the machine.
    I think it's time for a new secondary transfer roller, but I guessing that the registration roller is pulling too long on the sheet and creating the ripple. Again, the images I uploaded show the image failure on the front (I wiped the toner off that didn't fuse) and the back to show the actual ripple.
    Any ideas would be greatly appreciated.
    Thanks!
    This gallery has 2 photos.
  • OverKnight
    • Sep 2019
    • 55
    FYI, I just did back of the cover math and 60# + 80# should be 208 GSM? The paper supplier says it is 232 GSM. What say you?
    • Ziggy
      • Feb 2018
      • 693
      Attached is the Supported Substrate Throughput Assurance Guide for the C1100-C1085-C1070-C1070P-C71hc-C1060-C1060L-C2070-C2070P-C2060 & C2060L. If the media you are trying to run isn't in this guide then its not supported . I know the customer will say that they run this all the time. This doesn't change the fact that its not a supported media.
      With that being said it looks like you problem is happing before transfer because there is no image an the wrinkles. Is tray 4 the most straight path on this machine?
      • OverKnight
        • Sep 2019
        • 55
        OK, I've been in the printing game a long time and having a list of "recommended or confirmed paper stocks" is generally a safe place to start. Printing equipment, even digital presses like these have hundreds of adjustments that compensate for stock grain, temperature, humidity and speed. So the performance of the stock can and will always be the main issue, but not the ultimate answer. If these machines can print on synthetics like polyester and envelopes without question, label stock cannot be that tricky regardless of the brand.
        I've made a career out of working with printing machines and ultimately there are always adjustments to be made simply because of bad weather. Another hack that I know about label stock, is chilling. Literally. I put the stock in the refrigerator and lower it's temperature. The tack of the adhesive at room temperature is softer, more pliable. Chilling the stock stiffens it and makes more rigid, thus a temporarily stronger bond. There is a good chance that the 60# Gloss Label is the same grain as the 80# Liner, and that way the two easily wrinkle in line with each other. That being said, there still has to be a setting or adjustment to compensate for that defect.
        Thanks for the Guide, it will be helpful in the future!
        • qaraman
          • Oct 2019
          • 17
          Reduce fusing pressure from expert adjustment Dipsw 1-0=1
            • 22999
            If there's any doubt about the paper weight ... I weigh it. I have a gram scale. Figure out your area in meters squared. You'll want grams/meters squared.
            When you get a wrinkle like that, it's usually caused by uneven pressure or humidity or both. If it's before fusing that pressure will be at the registration rollers. Registration rollers are a consumable part, I believe it's 12M on the 1060, or 1M to 2M if your running NCR stock. The NCR stock causes the rubber to swell at the paper edges causing jamming, skewing, wrinkles, etc. If this is what you're seeing it's not just the registration rollers. Every rubber roller that the paper touches will swell in this same way.
            • OverKnight
              • Sep 2019
              • 55
              Yes, I believe it happens to coincide with the change of seasons. The higher humidity might be contributing to wrinkling the label stock. The fact it doesn't happen all the time, is normal in the world of printing. The stock is everything, so is the weather.
              As for the roller, the manual states the replacement of the registration roller at 1,400,000 prints [Page F-4, Section (14), Number 1, Registration section, Registration roller, A50U7101]. Current count on the roller stands at 1,007,497. That being said, labels are the only product of the machine at 11" x 17".
              I will check the roller for inconsistency and try and tweak the settings. Thanks!
              • OverKnight
                • Sep 2019
                • 55
                I think that answers the question, blackcat4866
                I did a test strip method on the roller pressure and the center is loose when supported on both ends with matching strips of 20lb. paper.
                Time to order a new registration roller. LOL
                  • 22999
                  Let us know how it goes. Thanks for following up.
                  • OverKnight
                    • Sep 2019
                    • 55
                    OK, I admit it. I took a vacation.
                    As I was goofing off, the new roller came in. Second day back, I went to dismantle and replaced the roller. Had no issues with that.
                    Zeroed a few things out to start at a baseline, Registration Loop Adjustment, Thick to 0, Tray 4 Large Size to 0.
                    The crease still occurs. Reintroduced the settings back into the Registration Loop Adjustment to double check and it remains the same.
                    I assumed the idle roller is true and the pinch against the registration roller should be equal now. So I checked the paper pressure again with strips of 20 lb., and the middle is still is loose?
                    So now the question is, do I have a physical issue or a digital setting issue? Physical is in bold below:
                    4.2.25 Printer system: Paper crease, Bleeding
                    1. Paper Direction
                    2. Changing the Separation AC
                    3. Temperature Gap of the Fusing Edge and the Middle
                    4. Changing the fusing pressure
                    5. Changing the paper
                    Reduce fusing pressure was suggested before, but I need to find the setting. I don't see [Change Fusing Pressure] on the panel. Changing the paper is not an option. The stock here is custom made for their purpose and using it was always the plan. There is a back-up C6501 that handles the paper fine... it runs off steam, but still prints. LOL
                    I'm guessing... but I believe there is a bit of a timing issue here. The paper is fed into the registration and will shift the paper according to setting. After that, the paper advances to the transfer roller where the image is transferred onto the paper, the paper is lead into the fuser and for some reason, the registration roller is still shifting causing a buckle when it should have completed that operation?
                    FYI, this is an issue with text. Creases every time.
                    Let me know if you have any ideas and in the meantime, I will try, try, try again.
                    Thanks!
                    • OverKnight
                      • Sep 2019
                      • 55
                      OK, going with a timing issue in mind, I created a registered paper profile and changed the fuser speed +100. The crease diminished. Set it to +150 and it disappeared entirely. Should have thought of it earlier, because this is most likely a seasonal issue. Temperature and humidity are up, and the crease became chronic.
                      Now the magnification is off, but that's another tweak to process!
                      • OverKnight
                        • Sep 2019
                        • 55
                        After getting the label stock to run well a few things persist:
                        1. The image is still crooked. It looks worse than before, but still an issue nonetheless. The actual image at the top of the page clearly visibly skewed. I have adjusted the registration to compensate, but doesn't appear to do much. Also tried the fuser swing, but that is not effective either. This has been an issue for sometime and has been "forcefully" corrected using tray alignment on the Fiery.
                        2. Running text weight is still creased. I ran a color calibration on 80# Coated Text and no matter what, the crease is still present. This is where I should have started, getting text weight to run correctly. Thing is, this is a production machine and getting it to run the label stock was the priority. This machine used to run everything, 20#, Carbonless, 80# Gloss Text, and the custom Tabloid Label Stock. I firmly suggested getting a smaller copier for the regular 20# and Carbonless printing, it kept jamming in the C1060. Well, you run label stock with adhesive...
                        I now have the system running AND printing ALMOST perfectly on the label stock required. I take this as a win. Problem with creasing is still present and running anything other than thick stock is still and issue. With the machine running, I am going to replace the next possible roller that is in the line of process and close to expiration, A50U520001 2nd Transfer Roller/L. This is a more expensive roller, but I definitely have a problem between registration to fuser. This being the middle man, we move closer to the fuser with new rollers.
                          • 22999
                          Are you seeing any J10-01, J17-01, or J17-02 jams?
                          " ... I suspect that during a bypass jam removal, with paper pressing the bypass separation tire down, enduser pulls open the imaging drawer. The bypass separation assembly is deformed and separation roller drops out. Upper pre-registration guide M1 is scratched and bent. The downward warp delays the front side of heavier media. Remove the bypass assembly to reform the brackets and re-assemble. Temporarily re-form upper pre-registration guide M1. Eventually it may become fatiged and break at the front hinge. Replace guide plate M1 (A50U 8178 00) and sheets ([2] A50U 8863 00)."
                          • OverKnight
                            • Sep 2019
                            • 55
                            Reliability of the stock has been rather high, with only minor jamming due to doubles and web splices sneaking into the pile. The stock is always pulling from the PFU, Tray 4.
                            The history of the machine code errors are, J10-01=0, J17-01=64 and J17-02=0.
                            M1 was confusing. M1 is the entire ADU Carriage and Part No. A50U 8178 00 is actually M2 with "sheets" A50U 8863 00 being little sticker guides above idle rollers. I have inspected it and see nothing that would be significant, no warp, bends or scratches that would lend to a delay. The quote also says "bypass assembly" while I believe this is the duplex section according to part numbers stated.
                            I have checked the paper path to some degree and have not seen any debris or reason for disruption. However, there are bound to be worn items that cannot be seen by eye, so I don't discount that possibility.
                            There is a solution, just will take patience and perseverance!
