C450i, installing FS-533
  • copyman
    Owner / Technician
    • Sep 2005
    • 4713
    Originally posted by KMFLT3CH
    FS-533 was replaced with FS-542 for the newer 1i series machines.
    Thanks. Thought I saw that posted on this forum before but when I looked at C361i series data sheet it shows the FS533 (see attached). Maybe that is old data sheet?
      • 8167
      This fan is removed when installing any finisher.
      Because the bridge unit & inner finishers have their own fan.
      • tsbservice
        Field tech
        • 8020
        MK-607 fan kit is mandatory for FS-533 installation on 45/55 ppm color and mono i-series.
        • tsbservice
          Field tech
          • 8020
          #19
          FS-533 part numbers are slightly different between EU and US so you should be correct.
          A2YUWY1/A2YUWY2/A2YUWY3 EUROPEAN TYPE
          A2YUWY1/A2YUWY2 USA, CANADA
