C450i, installing FS-533
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    Going to install FS-533 (inner finisher) on this C450i but install instructions shows MK-607 which is a fan assembly to be installed as well. Can the FS-533 be installed without this MK? It's going to be in a very low volume office. Thanks
  • Synthohol
    Certified Konica Expert
    • 5842
    there are no footnotes on the price sheet for the fs-533 that show it requires anything else. no kits needed.
    if you have access to mkm the .xls spreadsheets with price and compatibility are very helpful.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      See attached pics install instructions
      • Synthohol
        • 5842
        on the current configurator https://configuratorp.kmbs.us/#/buil...c450i-71-c450i the 533 is not even an option anymore.
        • 4Toon
          • Mar 2023
          • 112
          We do install the fans here. I have not tried it without it, but I assume it is there due to the higher heat of the fuser, which could cause plastic to warp.
          Permanently banned from Konica SSD.
          • tsbservice
            Field tech
            • 8020
            It's mandatory kit according to my docs.
            We also didn't tried without fan...it may work but who knows.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4712
              Thanks everyone. I'm going to test without while in my shop just to see if it even works. But will add fan before installing machine at customer.
              • tsbservice
                Field tech
                • 8020
                That's wise decision.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4712
                  Ha-ha , last thing I want is a "meltdown"
                  • Esron Thomas
                    • Oct 2024
                    • 38
                    I tried but the fan cannot fit in the location allocated in the installation manual
                    • kingarthur
                      • 1364
                      I fitted one about 2 months ago, it was straightforward
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4712
                        When I finally installed the fan like king posted it was straight forward. I just followed the FS533 instructions for the specific model.
                        • copytechman
                          • Nov 2008
                          • 945
                          The FS533 isn't available for the newest models now, from the C450i catalog tho:
                          FS-533 FS-533 Finisher (50-sheet inner staple finisher): bizhub C550i / C450i: Requires MK-607
                          bizhub 550i / 450i: Requires MK-607
                          Regards.
                          A.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4712
                            Regards.
                            A.
                            Not sure what you posting? We know the C450i, 550i use the MK-607?
                            Just to be clear you are saying the new 1i series will not use the FS533? I still see it listed on the 1i options.
                            • KMFLT3CH
                              • May 2017
                              • 240
                              FS-533 was replaced with FS-542 for the newer 1i series machines.
