Going to install FS-533 (inner finisher) on this C450i but install instructions shows MK-607 which is a fan assembly to be installed as well. Can the FS-533 be installed without this MK? It's going to be in a very low volume office. Thanks
C450i, installing FS-533
there are no footnotes on the price sheet for the fs-533 that show it requires anything else. no kits needed.
if you have access to mkm the .xls spreadsheets with price and compatibility are very helpful.We know a thing or two because we've seen a thing or two.
The medication helps though... -
on the current configurator https://configuratorp.kmbs.us/#/buil...c450i-71-c450i the 533 is not even an option anymore.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
We do install the fans here. I have not tried it without it, but I assume it is there due to the higher heat of the fuser, which could cause plastic to warp.Attached FilesPermanently banned from Konica SSD.👍 2Comment
It's mandatory kit according to my docs.
We also didn't tried without fan...it may work but who knows.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
I fitted one about 2 months ago, it was straightforwardTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
The FS533 isn't available for the newest models now, from the C450i catalog tho:
FS-533 FS-533 Finisher (50-sheet inner staple finisher): bizhub C550i / C450i: Requires MK-607
bizhub 550i / 450i: Requires MK-607
Regards.
A.Comment
Just to be clear you are saying the new 1i series will not use the FS533? I still see it listed on the 1i options.👍 1Comment
