C450i, installing FS-533
  • copyman
    Owner / Technician
    • Sep 2005
    • 4593
    Going to install FS-533 (inner finisher) on this C450i but install instructions shows MK-607 which is a fan assembly to be installed as well. Can the FS-533 be installed without this MK? It's going to be in a very low volume office. Thanks
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5777
    there are no footnotes on the price sheet for the fs-533 that show it requires anything else. no kits needed.
    if you have access to mkm the .xls spreadsheets with price and compatibility are very helpful.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4593
      See attached pics install instructions
      • Synthohol
        • Mar 2016
        • 5777
        on the current configurator https://configuratorp.kmbs.us/#/buil...c450i-71-c450i the 533 is not even an option anymore.
        • 4Toon
          • Mar 2023
          • 108
          We do install the fans here. I have not tried it without it, but I assume it is there due to the higher heat of the fuser, which could cause plastic to warp.
          Permanently banned from Konica SSD.
          • tsbservice
            Field tech
            • 7951
            It's mandatory kit according to my docs.
            We also didn't tried without fan...it may work but who knows.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4593
              Thanks everyone. I'm going to test without while in my shop just to see if it even works. But will add fan before installing machine at customer.
              • tsbservice
                Field tech
                • 7951
                That's wise decision.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4593
                  Ha-ha , last thing I want is a "meltdown"
