C360i
  • rrrohan
    • Sep 2011
    • 1976
    C360i
    Stuck on 2 codes on a C360i where it would lock up completely
    first it was C40C5: CTL PF transmission timeout 2
    So I changed the CPU board. same error so i changed the sub board (MFPB)
    At first I thought it was ok but few days later got reports of issues again.
    Needs the SSD update as its on G01-01 but it gets to screen to update but no start button to begin and leaving it untouched for 15 mins doesn't start it neither.
    I know the symptoms of the old SSD firmware aren't the same as im experiencing but the fact it wont take update makes me think that there is a fault and that it may be causing the lockups im seeing.
    Should I order a replacement storage board AA2JM72702
  • tech51
    • 846
    • tsbservice
      Field tech
      • 7983
      Re: C360i
      I only update SSD firmware on this series when Storage controller firmware is AA2J0Y0-6501-G01-07.
      Easy to check via web interface or in CE mode. Never attempted on other types of SSD as it's not for them.
      • tech51
        • 846
        Re: C360i
        • tsbservice
          Field tech
          • 7983
          Re: C360i
          Alas they did it right but I don't bother waiting for it while quick check reveals if SSD update is worth.
          • tech51
            • 846
            Re: C360i
            • rrrohan
              • Sep 2011
              • 1976
              Re: C360i
              it was on G01-02 which is older than G01-07 so i thought it needed it. maybe not.
              yeah it takes normal firmware ok
              Just locks up after a print job and even though print job finishes the screen freezes
              also only way i can get into service mode in via trouble reset, if i go the normal way it locks up the second i click in after typing CE code
              • Albonline
                • Sep 2008
                • 1144
                Re: C360i
                did you run the self diagnostic mode? I've seen this before and it turned out to be the base board.
                • rrrohan
                  • Sep 2011
                  • 1976
                  Re: C360i
                  already put a new base board in and CPU board.
                  ive ordered a new SSD to try
                  • Woxner
                    • Jul 2011
                    • 841
                    Re: C360i
                    Have you tried reformatting the hdd. Fixes a lot of issues. It may not be bad.
                    • rrrohan
                      • Sep 2011
                      • 1976
                      Re: C360i
                      I don't think it has a HDD from memory
                      Sent from my Pixel 4 XL using Tapatalk
                      • Woxner
                        • Jul 2011
                        • 841
                        Re: C360i
                        Its attached to the cpu also known as memory. Everone gives it a different name. Acts as a hdd
                        • rrrohan
                          • Sep 2011
                          • 1976
                          Re: C360i
                          oh the NVME drive, yeah i wasnt aware you could format them. if thats the case i could of taken one from one of the many DOA (drunk forklift driver i assume lol) C360i I have? i ordered a new one thinking it was like the other boards where you can use 2nd hand parts
