Bizhub 4000P Invalid Config/Unsupported Cartridge
  • Mr.Weston
    • May 2025
    • 5
    Does anyone know where I can get my hands on the original firmware file for the Bizhub 4000p???
    I am getting the message about "Invalid Factory Configuration" and "Unsupported Cartridge". I've tried to reset it from the menu to factory defaults and other solutions I've found online and nothing works. I'm hoping I can flash it to the original firmware and the at will fix the issue. Details below. Thanks in advance!
    Details:
    Device Information
    Page Count = 10272
    Installed Memory = 1280 MB
    Processor Speed = 800 MHz (2)
    Processor ID = baecc030a11dd57e
    Serial Number = 45145PHH2TM5P
    TLI = 35SK300
    Engine Mode = 0
    Machine Type = bizhub 4000P
    Asset Tag = A63R011010048
    Hard Disk Last Erased =
    Printer Memory Last Erased =
    CalStat = 00000000
    Engine ID = 50
    Fuser Type = 00
    Loader = LW50.PR2.P544-0
    Kernel = FW5.CY.F544-0
    Base = LW50.PR2.P544-0
    Network = NH5.CY.N543-0
    Network Drvr = LW50.PR2.P544-0
    Engine = FDN.PIR.E618-0
    Panel = v2.3e3.3hw5c129
    Green Micro = Boot_v00.00-App_v01.12
    Font = 8.31M02-U5.021
    Tray 2 = A14.24_B1.10
    SID =
  • AlaskaCopyTech
    • Jan 2024
    • 78
    There is a guy on here that has a bunch of firmware I think you can send him a DM. Synthohol do you know anyone with 4000P firmware?
    • Mr.Weston
      • May 2025
      • 5
      Thanks! Is that guy Synthohol or does he just know the guy?
      • Synthohol
        Certified Konica Expert
        • 5891
        Been on vacation.
        Anything I have is 2+ years old.
        I retired and have no access.
        • Mr.Weston
          • May 2025
          • 5
          It's probably a 10 year old printer so the older the better!
          • Mr.Weston
            • May 2025
            • 5
            Anyone at all able to help or point me in the right direction?😔
            • adfgdf
              • Jan 2022
              • 12
              Did you nistall a non original toner? Have done the same mistake, so we use only original in order to work...
              The FW version you have instaled is one of the "oldest".
              • Mr.Weston
                • May 2025
                • 5
                No, we had old toner and it's branded Konica Minolta. Both empties and "new" are authentic and giving same error
