C308 boot screen
+ More Options
Posts
  • copyman
    Owner / Technician
    • Sep 2005
    • 4756
    C308 boot screen
    Hi,
    Just picked up an off lease machine. How can I get rid of a custom boot screen with last dealers name on it?
    Think I was helped on this forum with same issue before but can't find the info. Something with a boot screen tool? I should still have the tool if that is required.
    Is there an easier way to return boot screen back to kon/min default screen without using a special tool, etc? Maybe format HDD?
    Thanks for the help
  • Synthohol
    Certified Konica Expert
    • 5888
    • copier tech
      • 8198
      Re: C308 boot screen
      Originally posted by copyman
      Hi,
      Thanks for the help
      Turn Power Off inside front door Press and Hold Yellow Reset Button & Keep Held Down while turning power back on until a black dot appears in the top right of the control panel display then release. On the next screen you have the option to delete the previous owners boot screen logo.
      โ€‹
      • copyman
        Owner / Technician
        • Sep 2005
        • 4756
        [QUOTE=copier tech;2100328]
        Thanks for the info. Just to be clear it didn't show "delete previous", you simply touch "boot screen" tab and you will see it change. Turn machine off and on and will be set back to factory boot up screen. Never doing it before I pressed the "orange" start button & trouble reset but don't think you have to do that.
        • copier tech
          • 8198
          [QUOTE=copyman;2100926]
          The trouble reset option is to clear various errors once you have resolved the cause, fuser overheat, trapped paper behind the paper try etc.
          โ€‹
          • copyman
            Owner / Technician
            • Sep 2005
            • 4756
            [QUOTE=copier tech;2101336]
            Yes. I know but it was weird that nothing happen when I highlighted "boot screen" so I pressed the orange print and trouble reset. Ha-ha I usually don't start pushing buttons but knew it wouldn't hurt anything. Now I know to just highlight the tab then turn off and on main switch.
