C458 Stop Printing
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 162
    C458 Stop Printing
    Greetings Programs,
    I have a client with a C458 that will not print.
    There is no error code.
    The only indication is the job message in the top right of the screen says "Stop Printing".
    Print jobs sent from PC, Copies, and Demo Page/Meter sheet all have the same result.
    The fan will spin up in prep for a print job, but it won't pull paper.
    Scan jobs function normally.
    I have done initialization, physical and logical format, and firmware update (I had to disable the HD to get the FW to update).
    I'm stuck on this one...
    Any help is appreciated!
    Thanks!
  • Thib
    • May 2017
    • 35
    I see this when the lifestop settings are turned on.
    Svc mode - stop, 0, clear - life stop setting.
    • FuserNoob
      Service Mgr, CISSP
      • Jul 2022
      • 162
      Oooh, forgot about that!
      Thanks!
      • FuserNoob
        Service Mgr, CISSP
        • Jul 2022
        • 162
        That was it!
        Thanks!!
        • Brad6784
          • Mar 2015
          • 84
          Great shout, nice one!!
          • nullskull
            Learning
            • Aug 2023
            • 485
            What is lifestop?
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5891
              it stops telling you to change the worn/used consumable.(not toner)
              • KMFLT3CH
                • May 2017
                • 242
                What is lifestop?
                Nah, life stop is just what it sounds like. Once the consumable has reached end of life, the machine ceases any copy/print operation. There are no error codes or messages on the panel about consumables needing to be replaced. The machine just stops until you disable that setting in service mode. I've seen this on a bunch of machines which is odd because the setting should be disabled by default.
                The settings for the warning messages you're thinking of is under System 2 > Unit Change
