C-450i Firmware
+ More Options
Posts
  • CP-1015
    • Nov 2020
    • 325
    C-450i Firmware
    According to the diagnostic tool is the SSD OK. If boot problems still occur (50%), download the firmware. Can someone please send me the appropriate firmware? Thanks!
  • copytechtrouble
    • Nov 2020
    • 112
    change the CPUB. its the CPUB!
    • CP-1015
      • Nov 2020
      • 325
      Great, the customer will be happy.
      • CP-1015
        • Nov 2020
        • 325
        Edit: Isn't there a special firmware for strangers SSD? I'm not shure but think colleage has switsched the SSD.
        • copytechtrouble
          • Nov 2020
          • 112
          yes sorry, if the SSD was changed with a new one it may need to have the boot rom updated. try that first before changing the CPUB.
          I've attached the bulletin with details on how to update the boot rom.
          • CP-1015
            • Nov 2020
            • 325
            Now I know; SSD is original. Is it helpull to try another SSD because the SSD destroys the CPU? Is a bootrom update even possible with the attached screen?
            Is the CPU available anywhere outside of Minolta? Many questions, thanks a lot.
            • Max
              • Oct 2011
              • 569
              Update boot and storage controller regardless. Even the updated Diagnostic/recovery tool doesnt detect CPU board failure unfortunatly.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4782
                Hytec dealer services, Orlando FL, you can send CPU in for repair, exchange or buy outright
                • CP-1015
                  • Nov 2020
                  • 325
                  How can I do? With F000-GXX-34(00) and F231-G00-RE(00) it seems impossible.
                  • CP-1015
                    • Nov 2020
                    • 325
                    Thanks, but I'm from Germany. And I thought it''s a normal computer cpu. But I can't find it anywhere. CPUs are usually located on the motherboard.
                    • CP-1015
                      • Nov 2020
                      • 325
                      Is cpu board non standard board?
                      • Max
                        • Oct 2011
                        • 569
                        If the copier restarts every 10 second then you cant. If it doesnt boot up then Insert the latest firmware and follow Copytechtrouble advice.
                        The cpu board is non standard unfortunatley.
                        • CP-1015
                          • Nov 2020
                          • 325
                          I don't get the display Copytechtrouble showed, it stops at display from #6.
                          • CP-1015
                            • Nov 2020
                            • 325
                            Firmwareupdate with F231-GG3-RB was successfull. CD-313, Datarecovery. Issue solved. I hope not only in the moment.
                            • DeWalt_Man
                              • Jul 2023
                              • 24
                              lucky, cpu boards are really expensive and hard to get if ur not a dealer.
                              if you get the issue again, hold the standby button during boot and check the attatchment. it shows the boot process and shows how to solve issues when booting.
