Differences between rollers
  • Digital
    • Feb 2021
    • 19
    [Misc] Differences between rollers
    Hello guys,
    i want to know if someone knows the differences between A00J563600, A64J564101 and A64J564101. I know that the last two that i mentioned have the clip, but i want to know if the are some differences in the materials, or if someone last longer than others.
  • KMFLT3CH
    • May 2017
    • 242
    Re: Differences between rollers
    AA2J560000 (light blue with clip) is the newest and is made of a harder compound than the A64J564101
    A64J564101 (pink with clip) is harder than A00J563600
    A00J563600 (red, no clip) is the oldest and softest.
    • Woxner
      • Jul 2011
      • 854
      I was told the red ones are the same just different shafts. I chuck the blue seps on i series and use the red one. Stops a lot of jams
      • Toxic
        • 698
        Yes, red ones are the softest material and have best grip but also wear quickest.
        From my experience they can last at least 100-150k and that is ok for the price.
        I replace only red rubber from A00J563600 for ADFs separation rollers too .
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          We used to do that too until we discovered the blue 9J07340901 is a direct drop-in replacement (no need to slide the rubber off the center) and lasts twice as long (since it's quite a bit harder rubber) as using a red A00J563600 rubber. Because the blue one lasts so much longer, the ADF feed roller wears out about the same time but when using the red sep, it would wear out WAY before the feed would. So, especially on high volume scanning customers, we just put on the blue one at the same time as a new feed roller.
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • tsbservice
            Field tech
            • 8064
            Originally posted by srvctec
            We used to do that too until we discovered the blue 9J07340901 is a direct drop-in replacement (no need to slide the rubber off the center) and lasts twice as long as using a red A00J563600 rubber. Because the blue one lasts so much longer, the ADF feed roller wears out about the same time but when using the red sep, it would wear out WAY before the feed would. So, especially on high volume scanning customers, we just put on the blue one at the same time as a new feed roller.
            Side question; will this blue roller work better in place of red ones separation rollers (A00J563600) in paper feed units?
            • srvctec
              • Oct 2009
              • 827
              Not sure, haven't tried that yet but I bet they would. You would have to slide off the blue rubber and swap it for the red, though since the center is different.
              I should clarify a bit. We put the blue ones on when the feed roller is A143563100 (the on with the white center and gear built in). Can't remember what all ADF's those go on but the rubber on them seems a bit different composition than A00J563600 and it's clear instead of red. When paired with the blue, they work very well together for a very long time.
              • Digital
                • Feb 2021
                • 19
                Thanks to all for the answers. But i have something else to ask.
                For Tray Paper Feed:
                • A00J563600 (red, no clip) is the oldest and softest.
                • A64J564101 (pink with clip) is harder than A00J563600.
                • AA2J560000 (blue with clip) is the newest and is made of a harder compoundthan the A64J564101.
                So is right to say that AA2J560000 is the best roller for now?
                Should i use it in combination with A64J564101 like Konica do with i Series? Can i use it everywhere or it's better to stick to the rollers that Konica provides for every machine in its PARTS GUIDE MANUAL?
                For ADF:
                Is 9J07340901 + A143563100 the best combo for DF624?
                Is 9J07340901 + A00J563600 the best combo for most recent ADF (like DF629 and DF632)?
                • copier tech
                  • 8220
                  A64J564101 & A00J563600 are made from exactly the same material.
                  A64J564101 looks a lighter colour only because the shaft is grey.
                  • tech51
                    • 846
                    For ADF:
                    • rrrohan
                      • Sep 2011
                      • 1977
                      yeah i still just use a00j563600 for almost ever rollers replacement
                      Ive always just swapped the rubber. same with a108563900 sep rollers, just used the a00j563600 rubber.
                      • avecosat
                        • Jun 2012
                        • 305
                        +1 I prefer these rollers
                        • Digital
                          • Feb 2021
                          • 19
                          What about AA2J560000?
                          Does its hardness compromise functioning or it's better because it's harder than A00J563600?
                          In i Series the tray upper roller is A64J564101 and the lower is A00J563600. Why both? Why not only 1 type of roller?
                          EDIT:
                          i found this KONICA MINOLTA INC. BSLJ-WEB
                          They wrote that :
                          In order to improve serviceability, for "Paper feed Roller" at the following positions, New "Paper feed Roller" (AA2J560000) with improved in abrasion resistance by changing
                          the rubber material has been added as serivce parts.
                          This is valid for 4 series and 8 series.
                          • KMFLT3CH
                            • May 2017
                            • 242
                            For ADF:
                            For ADF sep roller I use A3CFPP4H00 on EVERY model. it's basically a A00J563600 + torque limiter + metal shaft held inside a black holder. they fit everything, and in case it's an older machine with a white holder, just pop out the 4H00 roller+limiter+shaft and insert into the old style holder. They work fantastic.
                            • srvctec
                              • Oct 2009
                              • 827
                              [ATTACH=CONFIG]52267[/ATTACH]
                              That part is absolutely ridiculously priced at over $60.00 our cost which is why we stopped using it vs. just around $10.00 for the A00J563600 rollers. I don't remember the last time I had a torque limiter cause an issue. I think I've replaced 2 in 33+ years on any machine in any place (not just ADF).
