Dirty line on page edge C224e
  • stefankent
    • Feb 2022
    • 5
    • 23009
    Re: Dirty line on page edge C224e
    Yes, the magenta developer is bad again. Are you using knockoff toner? How many copies on the magenta drum?
    Try printing these images:
    • stefankent
      • Feb 2022
      • 5
      • slytukana
        • Feb 2015
        • 48
        Its the charge not enough of the developer unit. contact at the back the once developer unit contact on. You have to remove the main drive unit in order to do that dust and corrosion affecting charge to leak
        Sent from my SM-A217F using Tapatalk
        • slytukana
          • Feb 2015
          • 48
          Transfer belt needed replacement
          • stefankent
            • Feb 2022
            • 5
            • Synthohol
              Certified Konica Expert
              • 5849
              There is something stuck under the cleaning blade of the belt.
              that streak is where the IDC sensors judge density but the patches are not getting clean.
              thats what it looks to me.
              • stefankent
                • Feb 2022
                • 5
                • femaster
                  • May 2011
                  • 1514
                  Check the drums and see if you have a similar band around any of them. Also, anything on the transfer roller in that area? When doing a singled sided print/copy, is there anything on the back side of paper?
                    • 14813
                    Remove the magenta drum, disassemble and clean the grid and needle.
                    • L0rdC
                      • Feb 2021
                      • 82
                      multiple colors on that line, I doubt it's from a single drum, the transfer belt cleaning blade is not working, have you replaced just the belt or the entire unit? I have had a similar line recently, changing only the cleaning blade corrected it, but in my case the line was brown/black because the printer almost always prints in black
                      • Gift
                        • Mar 2011
                        • 2459
                        +1 for the drum, you can swap it with another color to see if the dirty line changes the color.
                        • Hansoon
                          • Sep 2007
                          • 3389
                          Had today a BH-C-284e exactly like that. One of the disintegrated seals from the corona grid was captured under the TB cleaning blade. Hard to understand how it came there and didn't fall off earlier.
                          Hans
                          • iraklis7302
                            • Jan 2022
                            • 54
                            hello sir
                            could you please explain with more details your quote?thank you
