More i-series nightmares
  • Ziggy
    • Feb 2018
    • 810
    I came across one that another tech had a put in a brand new storage and cpu put in ,not at the same time, and was giving an error code that it wasn't giving before he started . I pulled storage and cpu boards and noticed that the storage board contacts were brown instead of gold. I cleaned them and the contacts of the cpu board with an old fashioned typewriter eraser. Put them back in updated boot rom and firmware and the machine came to ready .
    With that being said it would be a good idea to clean these contacts before ordering the boards and clean the new ones before putting them in.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4785
    I was at off lease warehouse yesterday to test & buy 3 super low meter i series C250i & C300i, all under 20k. 2 of them stuck on boot-up at 25 & 50%. 2 out of 3 machines bad! Not good odds to say the least. That explains the low meters and more importantly how bad this issue is with the i series! If this CPU / Storage crap isn't corrected with the new "1i" series it will be the beginning of the end for Kon/Min !!!!
    • REGSIS
      • May 2016
      • 437
      You can check those machines with recovery tool.
      It will show you bad SSD or CPU eventaly. Fusers are bad also. New fusers are reliable - so far....
      8 series is much better especially on print quality and heavy stock.
      • Ziggy
        • Feb 2018
        • 810
        Thanks, I'm well aware of the recovery tool but it doesn't always tell you what is bad. Plus I went in behind another tech that had already replaced the boards and started getting a different problem. That's why I pulled and inspected the boards
        • occus
          • 338
          Yes, true. It was serveral times advised here to clean contacts of CPUB here. And in the bulletin also.
