IC-420 on a Bizhub I series
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 90
    I have had a few of these Fiery controllers that won't assign the copier an IP address The config page from the Fiery shows an "engine network ID". How do I get an IP address to show up????
  • Ziggy
    • Feb 2018
    • 810
    It should assign one IP address higher than the fiery . ex. if fiery is 192.168.1.2 the machine should have 192.168.1.3 . If the fiery is setup to auto assign the 2nd page of the Fiery config page should have the machine IP . It may be that the address that the Fiery is trying to assign to the copier is already taken.
    • jwrycza
      • Sep 2013
      • 90
      The second page, like I said, says Engine Network ID,and then has a long string of numbers, not the IP address. I tried to ping 2 numbers up and 2 numbers down from the Fiery IP before I found out it was 5 numbers lower. This has happened on more than 1 since the 420 came out. I am trying to ascertain as to why and how to fix the issue.
      • Synthohol
        Certified Konica Expert
        • 5908
        Sounds like ip4 is off and ip6 is the default.
        Make sure the fiery is set to assign engine ip and make sure the copier is set to dhcp.
