Printer counter report, department, user separation, mail, report
  • File Depot
    • Apr 2025
    • 8
    Hi Guys,
    Konica Printers have defined department names.
    These department names are also registered in the printer settings on the computer.
    departments for example: "We can't answer when departments ask for 6 months consumption?"
    because we need to send a date-based mail, or we need a date-based breakdown counter report on a department basis.
    How can we track department and date-based counters without buying an extra paid software?
    Printers models:
    bizhub C257i
    bizhub C3351i​
    #see the number of printouts on a user-registered printer
    #distinguish user-verified prints
    receive mail in certain periods
    mail sending settings​
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    in admin, user authentication/acct track you can print it out.
    Print Counter List • The setting is available only when carrying out the user authentication or account track.• It will not be displayed when [Service Mode] -> [Billing Setting] -> [Management Function Choice] shows that vendor 2 is mounted.
    i think pagescope administrator would help.
    • kingarthur
      • 1356
      Or you can log in as an admin, via the web portal, and export all the counters, and then copy and paste into an excel sheet
      • File Depot
        • Apr 2025
        • 8
        Yes thank you, that was nice, we were able to transfer the .txt content to excel and see it.
        is there a date-based automatic method other than manually retrieving this data?
        job would be, it could be a free software,
        criteria: "date range and department name counter."
        • File Depot
          • Apr 2025
          • 8
          https://cscsupportftp.mykonicaminolt...productid=2469
          I'm sorry I didn't understand exactly what you meant, we can access the counters from the web interface, yes, but it's complicated,
          there is no date option, I can't find mailing by mail, thank you.
          • Synthohol
            • Mar 2016
            • 5824
            isnt there an option to email the counters and other info daily right from the copier? the place where you can have it email if there is a jam or code or just counter info.
            been almost 3 years since i retired but there should be the option.
            • File Depot
              • Apr 2025
              • 8
              yes we were able to send the counter by mail, but we could not get how much the registered printer users printed this counter because it writes the total prints. i understand you, thank you anyway.
