Firmware on bizhub 224e gone wrong
  • adecanmin
    • Oct 2010
    • 322
    #16
    Originally posted by Black Cloud
    This looks like NVRAM corruption. This is why I don't do firmware updates to the 4 series machines anymore. You only find out after doing firmware and because you did the firmware you get the blame for it. Sorry buddy. I wish I had better news.
    I'll have the machine in the shop tomorrow. Hopefully I can bring it back to life.
    • adecanmin
      • Oct 2010
      • 322
      #17
      Originally posted by Albonline
      if its rebooting with a jump drive in the firmware port. it s not seeing the correct startup files for what model it thinks it is on the drive.
      I'll try the reset software once I get the machine in the shop.
      • JMS
        • Apr 2023
        • 30
        #18
        Which firmware was on that machine before?
        When it is to low, there can be update-problems.
        We update older versions to version G20-M1, then to the latest firmware-version.
        • femaster
          • May 2011
          • 1526
          #19
          Originally posted by adecanmin
          Gentlemen
          Customer was having intermittent printing issues. I haven't updated the firmware on this machine. I installed FW_A61F0Y0-F000-GDS-M1.
          All the files installed and the print button was blue. I turned it off removed the flash drive and started up. Now it gets to one shark fin reboots and reboots. I tried to install a different firmware and it won't get past the first shark fin before rebooting. What happened? and is it fixable without having to replace circuit boards.
          Not sure about a single fin, pretty sure it jumps from none to 2. The second is very light compared to the first, but either way...
          Looking at the boot-up troubleshooting guide (attached) it looks like it could be something as simple as the extra stick of RAM has gone bad if there is one installed. Take a peak at the flow chart and it might give you an idea of where to start looking.
          • adecanmin
            • Oct 2010
            • 322
            #20
            Not sure. I can check later.
            • adecanmin
              • Oct 2010
              • 322
              #21
              Thanks. I'll look at it.
