Konica Minolta C754e customer move to another location
  • surecopy
    • Mar 2018
    • 42
    Hi I got a call that my customer moved this copier to another location and they said it was jamming and says Side door is open I went there to see and side door is fine but it is the duplex door it looks to be in place and I used a tool to push in interlock how do I get to the sensor there is a big metal plate do I need to remove that plate
    trying to get this up and running for them.There is a large capacity side paper feed unit there does that have to be hooked up.Thanks in advance Neil
  • stronghold
    • Apr 2023
    • 44
    You can attach a photo so that we can understand what you mean.
    You can get to the god door closing sensors only by removing the front white panel under the screen.
    • surecopy
      • Mar 2018
      • 42
      Good morning, Stronghold thank you for answering it is the duplex door if you open the main side door it appears that it is under the metal plate on the main side door
      • copyman
        Owner / Technician
        • Sep 2005
        • 4697
        Hi, Are you sure that sensor is bad? Did you test sensor in service mode? As for jamming the most common thing is paper dust on reg sensor, remove paper dust collector and clean "frog eye" sensors on machine and on collector.
        • surecopy
          • Mar 2018
          • 42
          Hi Copyman,I have been working on office equipment for over 30+ years. I do not usually work on km but time are getting tough the last few years. Can you help me to get into service mode Thanks Neil
          • copyman
            Owner / Technician
            • Sep 2005
            • 4697
            No problem. You can PM me and will provide all common passwords or send you SM which I think you should have regardless. Don't want to post passwords on public forum.
