Paper jam code 32-01 bizhub c454
  • iraklis7302
    • Jan 2022
    • 54
    Hi there
    i have a problem with paper jam code 32-01.there is no any paper nowhere in machine,but when i try to print both sides it appears this messAGE.as i saw the paper prints only in one side,the machine doesnt try to take the paper from both sides.it prints only one side and then appears this message.could anyone help me?this was presented from time i replaced the near door with transfer roller etc
  • tsbservice
    Field tech
    • 8051
    Re: Paper jam code 32-01 bizhub c454
    Gate switching solenoid needs some stickers under arm... mentioned in a lot of threads.
    • copier tech
      • 8200
      +1 on this they turn sticky you can peel them off completely.
      • iraklis7302
        • Jan 2022
        • 54
        Thank you ,I will try to find the threads
        • tsbservice
          Field tech
          • 8051
          Lol these pads/foams I forgot them...but agree always remove them.
          This time sorry mate I was meaning solenoid mode and there's no pads/foam there.
          • iraklis7302
            • Jan 2022
            • 54
            I tried to find any photo but nothing.could you please explain me where is gate switching?thank you in advance
            • kingarthur
              • 1385
              It's between the fuser and the exit, I suggest that you get hold of a service manual and go through the theory of operation.
              • iraklis7302
                • Jan 2022
                • 54
                • Gift
                  • Mar 2011
                  • 2459
                  Guess the problem might re-occure then - usually after the duplex hasn't been used for a while. In case it does you'll find the solenoid easy if you inspect the exit unit's gate mechanism.
                  • iraklis7302
                    • Jan 2022
                    • 54
                    ok thank you for your reply.i have solve the problem.It was from transfer roller door.it didnt closed so well so i had to fix it.now my machine prints great from both sides without any error.i appreciate all your help but in my occasion there wasnt any solenoid etc.....
                    • AlaskaCopyTech
                      • Jan 2024
                      • 78
                      Sorry to dig up an old thread but I have the same thing going on. Just removed two pads that made contact with the exit gate and I am still having the paper just plop out instead of duplex. I have inside the machine a different exit assembly from back in the day that was working in the machine I pulled it from. Would it be worth it to get a new exit assembly and try it?
                      • tsbservice
                        Field tech
                        • 8051
                        Better put holding part A7PU890800 on solenoid costs almost nothing...
                        • AlaskaCopyTech
                          • Jan 2024
                          • 78
                          Exit assembly already has it.
                          • tsbservice
                            Field tech
                            • 8051
                            Just removed two pads that made contact with the exit gate...
                            There are actually 4 pads for gate noise reduction. 2 on main body side and 2 on right door side. Did you remove all 4 of them?
                            • AlaskaCopyTech
                              • Jan 2024
                              • 78
                              Nope just saw the two where the gate hits on the machine side. I'll try to find the 2 on the right door side.
