C658 DV unit ?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4709
    C658 DV unit ?
    I see there are different part #'s for the C658 & the C368 developer units. But on some websites it shows the C658 dev unit part # same as the C368. Can the C368 DV unit be used in the C658?
    Thanks in advance
  • JasonSBE
    • Apr 2014
    • 186
    I believe it can, but you have to move the rail and possibly the front over from the one that's currently in the machine. The sensor that is inside the rail needs to be moved as well in order to reset the life setting, and to make sure the density is correct.
    • Ziggy
      • Feb 2018
      • 758
      here is the latest consumable by model pdf
