Bizhub 423 3001 jam - suspecting wrong tray 1 paper feed assembly
  • Techalyzer
    • Mar 2022
    • 26
    #46
    Re: Bizhub 423 3001 jam - suspecting wrong tray 1 paper feed assembly
    Originally posted by cyta123
    Try to change clutch A00FM20000
    [ATTACH=CONFIG]52598[/ATTACH]
    Try to read a topic before answering.
    • cyta123
      • Aug 2015
      • 46
      #47
      >>I have this weird problem with a Bizhub 423. At every print from tray 1, the paper jams, sometimes at the first sheet, sometimes after a few sheets. Always jam code 3001. 537K copies on the machine. I have found a similar thread here, and it mostly points to the paper exit assembly cable/connectors or the wrong type of paper feed assembly used for tray 1. I have checked the imaging unit, registration unit, fixing unit, paper transport, it all looks perfect, one of the best looking machines I've worked on, minimal to inexistent wear, nothing wrong mechanically.<<
      You haven,t changed this part as far, and problem still exist.
      >>have checked the imaging unit, registration unit, fixing unit, paper transport, it all looks perfect<< maybe looks fine, but works wrong.
      • Techalyzer
        • Mar 2022
        • 26
        #48
        Nothing new on the internet. Here ya go buddy:
        • Hansoon
          • Sep 2007
          • 3385
          #49
          No need becoming sarcastic.......
          Colleague is trying to help YOU with YOUR problem which YOU are not able to solve.
          Hans
          • tsbservice
            Field tech
            • 8016
            #50
            What will happen if you try bypass tray will it jam?
            • Techalyzer
              • Mar 2022
              • 26
              #51
              Hans
              Reading what I said would help a lot more. But it's ok, I have decades on the internet, and it is always the same. I repeated 4 or 5 times everything that I checked and replaced. Sometimes in bold. Other times in a list. Then there are quotes of what I said, repeating what I said even more.
              And then you have some wise guy going "Hey, have you tried replacing THAT?" REALLY? How would YOU react?
              Not cool...
              • tsbservice
                Field tech
                • 8016
                #52
                Not cool...
                Please stay on topic...there is really no need of snarky comments.
                Check this post about cutting some cable ties, also can you confirm first tray paper feed unit is right one for bh423 as femaster already said feed unit from slower models won't work propely here.
                Originally posted by D_L_P
                I once fought a J30-01 on a 423 with very similar symptoms. Turned out to be removing all the wire ties behind this cover:
                [ATTACH=CONFIG]33023[/ATTACH]
                It was a fairly new machine ~50,000. I had replaced the fuser, feed rollers, exit unit, etc. What lead me to the wire tie was disconnecting that harness (and manually catching every page as it came out) allowed me to run +1000 without any jams. Plugged it back in and got 1 jam every 100 copies or so. GL
                • Techalyzer
                  • Mar 2022
                  • 26
                  #53
                  Would printing from tray2 cause a jam if the first tray paper feed unit is not the right one?
                  • femaster
                    • May 2011
                    • 1504
                    #54
                    I'm pretty sure you had already confirmed the correct feed units were in the machine (though I'm too lazy to go back and look for sure), but to answer your question:
                    Yes it could cause a jam because the conveyance sensor on the tray 1 feed unit would be incorrect, and anything coming out of any of the trays would have to pass the sensor on the tray 1 feed unit. Incorrect sensor = JAM.
                    • REGSIS
                      • May 2016
                      • 435
                      #55
                      I didn't read the whole thread - time consuming.....
                      I would suggest action in this order:
                      -Confirm 1st feed assembly is correct one
                      -replace registration clutch and check (or replace) pre-reg sensor.
                      -replace registration roller (black one) and registration bushings (x4)
                      I had lots of J30-01 always registration clutch was the problem.
                      10 years ago I swapped 1st feed assembly from bh 423 to bh 283.
                      Bh 283 was running fine but 423 jamed randomly. Don't remember the code.
                      Learned that lesson very well.
                      • Techalyzer
                        • Mar 2022
                        • 26
                        #56
                        I finally found the correct tray 1 feed unit with the optical sensor. Same problem. Now tray 1 lift motor died as well.
                        • Albonline
                          • Sep 2008
                          • 1151
                          #57
                          did you try swapping the motors ?
                          • Techalyzer
                            • Mar 2022
                            • 26
                            #58
                            I am stepping up the game and using a multimeter and I also ordered a 24V power supply to test stuff like motors and clutches.
                            I measured the connector, comparing to the tray 2 motor output, that indeed sees a 24V rise when the command is given. 0V on the connector for tray 1. Flatline. I tried multiple trays, just to be sure, all ok, not bent, not broken.
                            As I said, this thing's software or boards are most definitely going crazy in some way. I know many people insist on checking the clutches, but 1) they have already been replaced multiple times, and 2) I've seen bad clutches and a machine with a bad clutch doesn't pass 30+ sheets of paper with the perfection of a brand new machine. It stops after 2-3 pages.
                            From tray 2, the paper stops right in front of the large 2 black rollers on the machine side, then is pushed from behind by the tray paper transport, while also not advancing through those big rollers and being crumpled under the registration section because it is pushed from behind, but blocked by the big rollers not moving. It's precisely as if the board doesn't command the clutch while commanding the tray transport unit. I am adding a picture of the rollers where the paper gets stuck from tray 2. Precisely in the middle of the rollers. The paper is being pushed into them, but they don't rotate even a tenth of a degree.2022-03-28 18_54_07.jpg
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4704
                              #59
                              Sounds like an electrical problem if clutches not energizing. Or the switch that turns on clutch. If the boards are same as a Biz 223 I should have them if needed.
                              • Techalyzer
                                • Mar 2022
                                • 26
                                #60
                                I now have the 24V PSU. I tested all clutches, they all work. Tray 1 motor is fine but it's not getting powered any more when the tray is inserted.
                                At this point, I am pretty sure that something's wrong with the boards and/or software.
