Plz help with C2060
  • topimpress
    • Jul 2017
    • 29
    Plz help with C2060
    I have this problem.. any suggestions.
    Thx
  • Ziggy
    • Feb 2018
    • 785
    What are your consumables at?
    • topimpress
      • Jul 2017
      • 29
      I use original Konica Minolta toner
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5851
        it would be easier to diagnose if you print all 4 color gradations and halftone test pages.
        so difficult to tell from a customer image.
        isolating the issue by color is highly beneficial.
        • Ziggy
          • Feb 2018
          • 785
          I meant what is the life count of drums, developer, coronas, 1st and 2nd transfer. As Synthohol said a halftone of each color would help. Test target 43 will give you a full and half density of each color plus several prints with different mixed colors.
          • Afanasy
            • Aug 2023
            • 29
            Looks like a charging corona unit that is not fully inserted.
            • kenpio
              • Dec 2015
              • 202
              Is this thinker paper? If it is I would look at the fuser speed in the paper profile.There are a couple adjustment with the speed of the paper and transfer pressure. Does this happen on one sided or two sided? I would just dial in the paper with those adjustments.
              KEN
