BH-C-3110, which SMB protocol
  • Hansoon
    • Sep 2007
    • 3391
    Which is the highest SMB protocol the BH-C-3110, can do?
    Never did FW update on these beauties. I have mainA6DT30GJD01-951.prn, is it easy to do?
    Hans
  • Ziggy
    • Feb 2018
    • 790
    From what I can find looks like SMB 2 is the highest this machine can do . You also need the latest Controller Firmware , which is Controller Firmware Version Release 9. I can send that as well as the latest main which is A6DT30GND01-951.
    Looking at the read me and reaching in to the cobwebs of my memory it looks lie you will need to load firmware in a specific order . bizhubC3110 Cont_A6DT30G0D00-899.exe > bizhubC3110 Cont_A6DT30G0D00-999.exe​> bizhubC3110 Cont_A6DT30GJD01-899.exe​> bizhubC3110 Cont_A6DT30GND01-951.exe​. Below is from the KM site. I can send you any and all files you want as well as the manual if you want it
    Version A6DT30GND01-951
    3/24/2021 67.91 MB bizhubC3110 Cont_A6DT30GND01-951.exe
    Release Notes: bizhub C3110 FW ver. main: A6DT30GND01-951 Support for enabling LDAP channel binding.
    SEE DLKM_BT2111806EN
    3/24/2021 146 KB DLKM BT2111806EN_01.pdf
    Version A6DT30GLD01-951
    11/30/2020 67.91 MB bizhubC3110 Cont_A6DT30GLD01-951.exe
    Release Notes: bizhub C3110] [FW ver. main: A6DT30GLD01-951] Black band at the edge of the paper occurs when printing a job from SAP.
    SEE DLKM_BT2021198EN
    11/30/2020 145 KB DLKM BT2021198EN_01.pdf
    Version A6DT30GJD01-951
    8/26/2019 67.91 MB bizhubC3110 Cont_A6DT30GJD01-951.exe
    Release Notes: bizhub C3110 FW ver. main: A6DT30GJD01-951 - AirPrint setting becomes invalid after updating to SMB2.0 compatible firmware (G0C02-9AV to GGD01-950), and 2 fixed.
    SEE DLKM_BT1929980EN
    8/26/2019 194 KB DLKM BT1929980EN.pdf
    8/26/2019 67.82 MB bizhubC3110 Cont_A6DT30GJD01-899.exe
    Version Release_9
    10/24/2018 67.91 MB bizhubC3110 Cont_A6DT30G0D00-999.exe
    Release Notes: bizhub C3110 Controller Firmware Version Release 9
    SEE DLBT1809934EN00.pdf
    10/24/2018 67.83 MB bizhubC3110 Cont_A6DT30G0D00-899.exe
    10/24/2018 71 KB DLBT1809934EN00.pdf
    Release Notes: bizhub C3110 Controller Firmware Version Release 9 README file
    • Ziggy
      • Feb 2018
      • 790
      I do remember if done in wrong order you can brick the machine
      • Hansoon
        • Sep 2007
        • 3391
        Thanks Zig, you have a PM 😊
        Hans
