Bizhub C3110 - black lines on the page?
  • milenjs
    • Mar 2022
    • 15
    It worked perfectly. He began to print these stripes on the pages. What could be the reason? Could it be black toner? Today I changed the black UI with another - no change.
    • 23005
    Re: Bizhub C3110 - black lines on the page?
    Can you identify a pattern that it repeats? =^..^=
    • Albonline
      • Sep 2008
      • 1147
      this looks like a 2nd transfer issue. look at the transfer belt .see if the image is good or bad. and work forward or backward from there.
      • tsbservice
        Field tech
        • 8003
        Did you happen to put non OEM toner recently?
        • copier tech
          • 8138
          Open the right hand door observe the transfer belt, can you see lines on it? You may need to use a flashlight/torch.
          • milenjs
            • Mar 2022
            • 15
            Yes - i use IT Image toner for Minolta Bizhub C20.
            Image is very good, only this black lines is a problem. Pattern - no repeats.
            • milenjs
              • Mar 2022
              • 15
              Here is it -
              • Albonline
                • Sep 2008
                • 1147
                clarify your problem, is the machine doing this on what's supposed to be a white output? or is it only giving you this instead of an image?
                • Gift
                  • Mar 2011
                  • 2459
                  Hard to imagine it's not the IU - perhaps the ITB cleaning unit isn't doing it's job or you had to make more prints after replacing the IU (guess it was a used one for testing?.
                  • milenjs
                    • Mar 2022
                    • 15
                    This is white page. Otherwise the print is good.
                    Replace IU with used one /for test/. No change - No change when printing. I printed a total of 50-60 pages for a sample. Here are 7 printed pages -
                    • tsbservice
                      Field tech
                      • 8003
                      You can remove transfer belt unit it's easy but be careful and examine belt surface or even better to stop machine mid-copy and check image on belt.
                      • milenjs
                        • Mar 2022
                        • 15
                        Now I only cleaned the drum of the black module / with a dry cloth /. I printed 7 pages. The result - the first is good, every next one gets worse.
