minolta bizub c308 c-d011 error
  • TIADO
    • Mar 2011
    • 10
    i have this error d011 on my konica c308, i need the files
    1. A7PU0Y0-F000-GXX-A8
    2. A7PU0Y0-F000-GXX-B0
    can someone help me my email : esalab@esagonoufficio.it
    Thank You!!
  • doinbox
    • Jan 2013
    • 113
    Thank You!!
    I do believe if you contribute to the website you will find it easier to get things like this
    • copyman
      Owner / Technician
      • Sep 2005
      • 4750
      Thank You!!
      I don't think F/W is going to solve that hard drive code. Have you tried backing up settings and formatting the hard drive? Try logical format first. You may also have a bad hard drive.
      • JMS
        • Apr 2023
        • 30
        It can be the error with SATA-Controller-firmware. Then he needs the 2 firmware files as described in the attachment here.
        • TIADO
          • Mar 2011
          • 10
          I've already tried replacing the hard drive with no success.
          • TIADO
            • Mar 2011
            • 10
            In fact, my problem is recovering these firmwares. Thanks
            • Slammers
              • Feb 2019
              • 152
              100%. If i ever get HDD errors on this series that is the first step to perform. If you blindly slap in a new HDD you get the same issues and I have seen others on this site write off the device as a bad MFPB.
              Depending on the FW level it can also present as a C-FA14 along with C-D011 and C-D055.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4750
                Don't you think it would of helped to mention in OP that you replaced the hard drive? We aren't mind readers. Just a waste of time! Best of luck
