C458 ERROR C.FA14
  • romario
    • Jun 2020
    • 193
    C458 ERROR C.FA14
    I have this error fa14, I changed the hard drive, I formatted the hard drive, I did a vlear data, I updated the fw to Y2, I put special fw that talk about this error, and the error still persists. Can someone give me a clue to solve it?
    thanks
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5891
    when does it happen? at boot? when RX a print job? if so is the driver the same version? is the function version matching the FW?
    • doinbox
      • Jan 2013
      • 120
      There is a slight chance it could be the board. I once had to replace the MFPB due to it throwing this error no matter how many HDD we tried. But at this point I would try another HDD if I was you.
      • Max
        • Oct 2011
        • 566
        Try a brand-new HDD, that never been used, if still errors out the mfpb board.
        • Jinn
          • May 2023
          • 137
          Before throwing the machine away try replacing the control panel
