c-4512, c-4511 error codes on KM c6000L
Re: c-4512, c-4511 error codes on KM c6000L
But only do this if it really is different and if you are sure the problem is in the laser.
4511 Laser Yellow
4512 Laser Magenta
4513 Laser Cyan
4514 Laser BlackComment
If you have 4511 and 4512, I suppose you shouldn't invert yellow laser with magenta.
Compare or invert with cyanComment
Below the laser, there is a sensor and an actuator that moves by steel cable through a motor inside the laser. Compare the problematic laser with a good laser. If it is different, open the laser and manually position it to the desired point. I always get a positive result like this.
4511 Laser Yellow
4512 Laser Magenta
4513 Laser Cyan
Perhaps, but that would be pointless. It will cease to be a production quality printer. =^.^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Ended up now ordering some used units entirely, because that's the only option.
Can you help me out what to do when swapping them? Really don't want to end up with 6 units on my hands 4 of which are just deadComment
Just follow the procedure in the manual, not too complicated.
Were it me, I would label each laser unit C1, M1, Y1, K1, C2, M2, Y2, K2. As long as labor time isn't a huge issue, I would replace Y1 with Y2, M1 with M2, and run adjustments. Then see if you get any additional codes. If it's the first time for you, it'll take you 1 1/2 to 2 hours to complete. If you have to go back in, it'll be quicker.
I personally have not experienced simultaneous multiple laser unit failures in the same machine, but I know of other techs that have.
I have anecdotal reports of a C6000 that pulled laser codes at 3 week intervals. The tech replaced three yellow laser units (each temporarily solving the issue). On the fourth laser installation, he also installed the PRCB. His theory was that the PRCB was overdriving the mirror adjusters, jamming up the worm gear drive. =^..^=Attached FilesIf you'd like a serious answer to your request:
I have anecdotal reports of a C6000 that pulled laser codes at 3 week intervals. The tech replaced three yellow laser units (each temporarily solving the issue). On the fourth laser installation, he also installed the PRCB. His theory was that the PRCB was overdriving the mirror adjusters, jamming up the worm gear drive. =^..^=Comment
Update on the whole situation, tomorrow the used one working prcb will arrive and my concerenes are about the firmware version of it. Didn't find any info on how to update it, except that it needs to be done if they're not the same.
┐('~`;)┌ no idea what to do on that, basically when do i get the fw or how to upload that
It's been a really long time since I did firmware on a C6000.
Like any of the Konica based devices, the folder structure is very important. So when you extract the machine firmware you'll have the basic folder structure, but none of the accessory firmwares. You'll have to download each accessory firmware separately and place it in the correct lettered folder, like the manual says. You'll want only the most recent firmware in each folder (not multiple versions).
The firmware I have is at least 12 years old, so it won't help you. Follow the instructions in the manual. =^..^=Attached FilesIf you'd like a serious answer to your request:
