image quality Konica C3350
  • Bassam_fisho
    • Apr 2022
    • 7
    [CQ] image quality Konica C3350
    Hello
    i have problem on my Konica C3350
    for prinitng text it's very good for black and color
    but if i priting Image it's not good
    i clean my macine good but same problem
    please any help
    i make resset settings my machine and same problem
    please any help
    thank you
    0d4cab6f-4279-4732-9c41-59cdfc05d8d6.JPG0ef89f07-feab-4b49-aede-0ac0d2ee4259.JPGb2cda8a9-5337-43c4-bff5-22845f2a43fd.JPGc8ea22d6-b5fb-4297-b341-acc629da554b.JPG99ea5fcb-bcdc-4473-9459-f77b433871c3.JPG
  • Gift
    • Mar 2011
    • 2459
    Re: image quality Konica C3350
    What's the consumable status of the IUs, ITB etc? OEM or not OEM toner?
    I guess you cleaned the laser glasses properly (with a cloth and glass cleaner)?
    • Bassam_fisho
      • Apr 2022
      • 7
      Yes i cleaned all good but same problem bro
      its. Full toner and its oem toner
      and also i repllace the unit for all same problem
      • tech51
        • 846
        Which units have been changed, please be a bit more specific.
        Also print the halftone test prints at 125 density and let us see them, that will help with diagnosing the fault.
        • Bassam_fisho
          • Apr 2022
          • 7
          i replace unit
          and its a test
          PHOTO-2022-03-25-23-38-18.jpgPHOTO-2022-03-25-23-38-26.jpgPHOTO-2022-03-25-23-38-35.jpgPHOTO-2022-03-25-23-38-41.jpgPHOTO-2022-03-25-23-40-01.jpgPHOTO-2022-03-25-23-44-39.jpg
          • tech51
            • 846
            • Bassam_fisho
              • Apr 2022
              • 7
              thanks dear
              service mode not working with me because CE password not working
              i trying 92729297 , 9272927292729272 , 12345678
              all passwords not working and locked failed
              • copier tech
                • 8195
                thanks dear
                Did you have any luck installing the reset tool ?
                • Bassam_fisho
                  • Apr 2022
                  • 7
                  no i not doing yet
                  • Bassam_fisho
                    • Apr 2022
                    • 7
                    i bought it from you and i still my machine not go to boot
                    anyway i will not need this machine i will sell it for anyone
                    thank you for trying help
                    • copier tech
                      • 8195
                      Last thing you could try, enter service mode from trouble reset. Power on the machine holding down yellow reset keyt then try the default password 92729272
                      • tsbservice
                        Field tech
                        • 8031
                        I think if CE password is changed from default you cannot use backdoor way to enter service mode due to unknown password. Easy to check though.
                        • Bassam_fisho
                          • Apr 2022
                          • 7
                          hello
                          thank you so much
                          i sold this machine and get new one
                          thank you so much
