KM Jam Code 3140 - HELP HELP HELP
  • reckless
    • Feb 2017
    • 188
    This is happening non stop when trying to print a sheet on C6100:
  • Albonline
    • Sep 2008
    • 1145
    Re: KM Jam Code 3140 - HELP HELP HELP
    What trouble shooting steps have you taken? different drawer? paper weight?
    • reckless
      • Feb 2017
      • 188
      Yes and yes. Nothing changes
      • reckless
        • Feb 2017
        • 188
        Ok it looks like machine was not 100% level properly. We found that the wheels were broken. Can anyone help me figure out the part number to these wheels? We can't find it.
        • Toxic
          • 697
          It should be this if you need rear wheels but i think machine have this 2 "legs" (16) and it is supposed to stand on them rather on the wheels.
          A0G6105100 Castor
          castor.pdf
            • 23002
            If it was leveled correctly on installation, most or all of the wheels won't be touching the ground. They'll be up on levelers. It takes a good 2 hours to get the entire setup properly leveled before continuing with the setup. =^..^=
            • reckless
              • Feb 2017
              • 188
              Two wheels in front touch and then two legs in the back. The two legs in the back are getting bent. Thats why I am confused.
              • reckless
                • Feb 2017
                • 188
                We spent hours today and made 100% sure its perfectly leveled BUT still paper jam doesn't go away. See below pics:
                The paper isn't stuck. It falls right out when drawer is opened.
                • Old_Tech
                  • Apr 2022
                  • 10
                  The J3140 is not a physical jam. It is During operation: During the printing, the main keeps operating without creating images or patches for a specified period. More than likely it needs the firmware updated.
                  • reckless
                    • Feb 2017
                    • 188
                    THANK YOU!!!!
                    How do I get the firmware?
                    • reckless
                      • Feb 2017
                      • 188
                      I got version G00-60 version 60. It looks like an upgrade from 50. I have to check but my feeling is I have original 2018 firmware which might be before version 50. Do I need to upgrade to version 50 before going to 60?
                      DLKM_BT2018410EN_01.pdf
                      • Old_Tech
                        • Apr 2022
                        • 10
                        You can jump to a newer version without processing from one current level to another. The other thing I would do is make sure the sensors that look at the intermediate transfer belt are clean and the shutter that covers them opens/closes smoothly.
                        • zayonc
                          • Jan 2022
                          • 49
                          [ATTACH=CONFIG]53006[/ATTACH]
                          WTF? Where are the rest of the sections? RU and FS.
                          • reckless
                            • Feb 2017
                            • 188
                            RU-518 with exit tray is attached. We left the perfect binder off while we releveled it. Room is a bit tight and allowed for easier access with it out of the way. Once it prints a few sheets we are adding it back in.
                            • zayonc
                              • Jan 2022
                              • 49
                              Re: KM Jam Code 3140 - ПОМОГИТЕ ПОМОЧЬ
                              Try to connect them
