Konica 223 doesn't add toner
  • dustzona
    • Mar 2015
    • 83
    Last week I changed out developer and drum kit on this machine because of light copies . A couple days later I got a call for light copies again . So I changed out toner supply motor because it was not turning in (manual toner add ) mode . The bottle doesn't turn nor does the motor that adds toner to the developer unit . I don't have much experience working on this machine so anything will help. I reset supply meters and did the TCR adj. .
  • Synthohol
    Certified Konica Expert
    • 5807
    Re: Konica 223 doesn't add toner
    vacuum out the subhopper.
    manual toner add only spins the bottle if the subhopper reads empty.
    • allan
      RTFM!!
      • 5462
      The toner supply drive on the sub-hopper gathers toner on the greased gears. That will lead to the motor not being able to drive the sub-hopper.
      Best is to strip out the sub-hopper and clean the gears properly. There is a lazy way to use the pipe fitting on a can of WD-40 and rinsing the gears while the sub-hopper stays in place.
      You should be able to hear the drive failing makes a soft grrr grrr noise.
      Whatever
      • copyman
        Owner / Technician
        • Sep 2005
        • 4643
        As allan posted I would look at the toner motor & drive assembly. Know you posted that you replaced motor but I would look at it again. Did you try using the manual add toner without bottle to see if coupling moves inside toner holder?
        • dustzona
          • Mar 2015
          • 83
          I appreciate the input from everyone . I ended up replacing the developer again and doing TCR adjust and that seems so far to have fixed the problem . thanks again
          • allan
            RTFM!!
            • 5462
            Hopefully its not running good prints due to the new developer having about toner in it. How many prints did you run after changing dev?
            Whatever
            • avecosat
              • Jun 2012
              • 304
