C454e constantly jamming
  • positiveg
    • Jun 2018
    • 299
    This has been happening close to a week now. No matter 11x17. Letter, 12x18 no matter orientations either just paper jam in the fuser20220509_155254.jpg
    Sent from my SM-G780G using Tapatalk
  • copyman
    Owner / Technician
    • Sep 2005
    • 4785
    Re: C454e constantly jamming
    Fuser clutch CL8 ?
    • tsbservice
      Field tech
      • 8064
      Jam code please.
      Looks like exit clutch
      • positiveg
        • Jun 2018
        • 299
        • positiveg
          • Jun 2018
          • 299
          Next this is this
          I changed all the drums the ibt belt and blade and I'm Stull getting prints with this issue. Please check the top
          See how it's lighter to the top of the print
          • tsbservice
            Field tech
            • 8064
            Originally posted by positiveg
            This is the error code[ATTACH]53242[/ATTACH]
            Yes replace paper exit Clutch (CL8).
            • tsbservice
              Field tech
              • 8064
              Next this is this
              Remove and clean PH unit.
              • allan
                RTFM!!
                • 5462
                Posting CMYK halftones helps so much to identify problems.
                The sensor flags can get worn out if the machine has a high reading. At about 1.3M things wear out.
                J-9202 I think is for the clutch.
                Then J-3205 if the pads that dampen noise on the gate goes sticky or if the sensor actuator on the duplex entrance on the door gets misformed by heat for the fuser.
                Whatever
                • positiveg
                  • Jun 2018
                  • 299
                  Thank You can you tell me the exact part number for this please thanks
                  • tsbservice
                    Field tech
                    • 8064
                    A161M20101, it's quite tricky to change this.
                    • positiveg
                      • Jun 2018
                      • 299
                      Thanks I found uit
                      so it's one right?
                      I have a tech who works on my printer, he's a Canon certified tech. We have no KM dealers here on island.
                      so it's only one gear this part is right?
                      thanks much for your help so far.
                      • positiveg
                        • Jun 2018
                        • 299
                        Remove and clean the PH unit?
                        Can you explain please thanks
                        • tsbservice
                          Field tech
                          • 8064
                          Thanks I found uit
                          so it's one right?
                          You will find all that in service manual and parts list... IMHO working on machine without them is a waste of time.
                          As far for asking about image formation problems pay attention what allan wrote, we need those patterns for better troubleshooting and it takes like 5 minutes to print them.
                          • positiveg
                            • Jun 2018
                            • 299
                            The images i couldn't print them because the printer is jamming so when i run those tests the paper joms in the fuser
                            I will look again for the manual think I bought it a while back
                            thanks much
                            • femaster
                              • May 2011
                              • 1526
                              Some halftone pages would be a great help here, but since you are also struggling with a jamming issue, get that resolved and then get the halftones. While the fade issue you are seeing can be caused by any number of issues, there are a few that can be the result of a dirty PH (Print Head) unit, also know as the laser unit in some circles.
                              Not sure what you've tried so far to remedy the fading, but the first step should be to try and clean the laser glass. There should be a cleaning wand attached to the inside front access door of the copier. Another possibility involving the laser unit is dust on the mirror motor inside the unit. On the Cxx4e models, the polygon mirror motor sometimes collects a layer of dust on the tips (corners) of the mirrors that write to the top (rear) edge of the drums resulting in a lighter, faded looking image. Fixing this requires removing the laser unit from the copier and carefully dismantling it, removing the mirror motor and very carefully cleaning off the mirror surfaces. Looking closely at the corners, the dust should be obvious if that is what's causing your problem.
