C458 developer spewing
  • alberto
    • Oct 2011
    • 12
  • Woxner
    • Jul 2011
    • 853
    Re: C458 developer spewing
    replace the HVPS. and possible the contact piece. you may also have to start with new dev unit as well
    • femaster
      • May 2011
      • 1519
      Has that machine had regular replacement or cleanings of the toner filter? If the filter gets clogged, it causes the ducts to get clogged and this can cause the issue you are seeing. Tends to mostly affect Cyan, but it can affect any of the colors or black.
      • alberto
        • Oct 2011
        • 12
        Thanks for the quick replies much appreciated
        i will check it out next week
        Just a bit puzzled as I have never seen this exact fault on a C224 or C454 and I work on them every day.
        2 C458 machines within a couple of days making me think is it unique to C458
        • tsbservice
          Field tech
          • 8053
          Not unique to C458, are you running drums and ITB unit past life? Good advices on HVPS and Toner filter/ ducts though.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4772
            Since you said you changed the developer & drum units and it came back have to ask are you using aftermarket toner?
            Like the other poster said "any" over life consumable and cause dev unit to short out, usually the cyan.
