CE Password Recovery
  • Alexsky
    • Mar 2009
    • 5
    #16
    Re: CE Password Recovery
    I agree with tulitron, and there is a way to return the default password
    I also have a solution too, valuable yes, because "almost" no one knows how to do it
    • techsxge
      • Jan 2022
      • 660
      #17
      1. Toggle off enhanced Security
      2. Do a Trouble Reset
      3. Press the Menu Button for 4 Secs
      4. You should ow see the Service Mode.
      This worked for me once, although it might be that i had special Firmware running.
      Since all Machines are able to run in a Network, you could use Tellnet to get into the Machine and either reset the password or just read it out. Have done this with older Machines, didnt bother with new Machines because i had then access to reset tools
      • techsxge
        • Jan 2022
        • 660
        #18
        Would you be willing to share this with me in private Message?
        • otphas
          • Aug 2019
          • 117
          #19
          This not work on 1051 !
          • Alexsky
            • Mar 2009
            • 5
            #20
            If you are willing to pay for information and knowledge?
            • techsxge
              • Jan 2022
              • 660
              #21
              If you're trynna sell some information, this forum might not be the right place for it.
              This is a Forum where we are helping out each other with our knowledge for free, not to make a quick buck
              • Alexsky
                • Mar 2009
                • 5
                #22
                Techsxge,
                I'm not trying to sell you any information,
                It was you who called me to share information in a private message, if you were as concerned about helping each other as you wrote, you wouldn't ask me for information in private,
                • otphas
                  • Aug 2019
                  • 117
                  #23
                  These Thread gone in wrong direction . If you want to help to the group do it , if not just dont answer , this model is normally very old and soon nobody will remember it or ask something about it . If you think you have gold in hand with your knowledge about CE pass recovery go in auction house and sell it .
                  • lillingtonnc
                    • Apr 2015
                    • 8
                    #24
                    not sure about c7000, other kmbs you enter service mode and IMMEDIATELY press stop 0 clear. there should be menu with ce password where you can turn it OFF
                    • Ziggy
                      • Feb 2018
                      • 695
                      #25
                      Originally posted by Elmo
                      Hi
                      Can anyone help i have had a Konica Minolta Bizhub Press C7000 come in and the CE Password has been changed
                      iam unable to get it from the previous customer
                      is there a procedure to reset it ? like with the C458 etc you can get a reset code to send to Konica
                      Thanks for any advise
                      Never had to do it but maybe this would work. Before the enhanced security settings can be disabled in Security Mode, enhanced security must be disabled in administrator settings. Access administrator settings, select Security and disable before accessing Security Mode and turning it off.
                      Then turn machine off and hold down the utility button while turning on and follow these steps.
                      1. "Service Mode menu screen"
                      Before selecting any item in the service mode, press the hard keys in the order shown below.
                      Stop → 0 → C
                      2. "CE/Administrator Security Setting Menu screen"
                      The CE/Administrator security mode starts up and the CE/Administrator Security Setting becomes available.
                      3. "CE/Administrator Security Setting Menu screen"
                      Select the item to be set to display the setting screen of each item.
                      4. "CE/Administrator Security Setting Menu screen"
                      Press [Close] to return to the "Service Mode screen."
                      Please let us know if this works. Free or charge
                      • tulintron
                        • Jul 2014
                        • 668
                        #26
                        I know how to do it and I do it in a minute.
                        When you need the service, just call me.
                        I charge the price of a technical visit
                        (PM).
                        Thanks.
                        • tulintron
                          • Jul 2014
                          • 668
                          #27
                          Originally posted by otphas
                          I have the same problem , but with 1051 pro , i cant enter in service mode , CE pass is changed and all know passes not work , i think i need new Nvram . I am not sure what will happen if i disconnect the battery on NVram , maybe will kill the Nvram ?
                          If you disconnect the battery from the NVRam, you will lose all data completely. She will not have any recorded information. ANYTHING.Counters - Zero
                          Serial - Zero
                          Adjustments - Zero
                          All other information - Zero
                          Impossible to get the printer to work like this again.
                          Need a tool to rewrite the data in NVRam.
                          By the printer itself you do this. All through her system.
                          She returns everything to Zero. But you can write something and get the printer to work again.
                          But it's not worth the work. More than a day to get back to normal
                          • otphas
                            • Aug 2019
                            • 117
                            #28
                            You can copy info from working NV ram and paste it to other one (not working) with a tool. I will write you when i am finish with this. Of course, it has an easier way and you dont need a hardware tool, but "colleagues " here want money.
                            • tulintron
                              • Jul 2014
                              • 668
                              #29
                              I made myself available because I know how to solve your problem. I don't think it's wrong to charge the price of a technical visit. Wrong or unfair is I throwing all my knowledge on a public forum.We helped each other. Only that. We don't make public what we know.
                              We saw in this post that Konica's direct technicians
                              Minolta don't know either and I showed you by video that with 20 seconds I would do it.
                              If you think the price is expensive, put your public knowledge to us. We will be most grateful.
                              Cloning an NVRam I don't do it because in any corner of the world, being a Konica authorized technician or not, it's a CRIME.
                              This is beyond my principles.
                              Good luck, "colleague"
                              • lillingtonnc
                                • Apr 2015
                                • 8
                                #30
                                try this, works on most kmbs. i have been turning off 9272s like crazy. enter service mode, IMMEDIATELY press stop 0 clear, should get menu where you can turn ce authentication OFF
