CE Password Recovery
  • emujo2
    • Mar 2017
    • 1579
    #31
    Re: CE Password Recovery
    Originally posted by tulintron
    I made myself available because I know how to solve your problem. I don't think it's wrong to charge the price of a technical visit. Wrong or unfair is I throwing all my knowledge on a public forum.We helped each other. Only that. We don't make public what we know.
    We saw in this post that Konica's direct technicians
    Minolta don't know either and I showed you by video that with 20 seconds I would do it.
    If you think the price is expensive, put your public knowledge to us. We will be most grateful.
    Cloning an NVRam I don't do it because in any corner of the world, being a Konica authorized technician or not, it's a CRIME.
    This is beyond my principles.
    Good luck, "colleague"
    That is because trained dealer and direct techs can call in and request a code to reset the CE password, not because "they don't know either"..I find it hard to believe that all the engineers in KM have not found your solution, and my guess is your procedure is harmful, or if it's a way to get around a customer imposed security feature that should not be disabled. E
    • tsbservice
      Field tech
      • 8053
      #32
      Originally posted by lillingtonnc
      try this, works on most kmbs. i have been turning off 9272s like crazy. enter service mode, IMMEDIATELY press stop 0 clear, should get menu where you can turn ce authentication OFF
      This is unrelated. We all know how to turn off CE password it's in manual. But to do that first of all one should know CE password. I never change default CE password although in some situations that may help prevent unauthorized access either by smarta** user or by competition.
      • Zoran
        • 52
        #33
        Maybe I can help you with my modest knowledge.
        The procedure is shown for the bizhub pro 951 and is the same for the c6000 c7000.
        You must be a skilled technician and confident in yourself, otherwise you will burn the machine.
        1. Remove the back cover of the machine.
        2. remove the plate shown in the picture.
        3.unload nvram
        4. with the parts thus removed, enter the service mode
        Hold down the bediener-zahler button and turn on the main switch
        5. when you have entered the service menu, carefully return the nvram to the bearings.
        6. press stop - 0 - C and turn off passford
        I can send you videos of me doing it
        • Zoran
          • 52
          #34
          This reset method keeps all settings, serial number of the machine and dials.
          Another way is to contact a Konica minolta service engineer who has access to the database.
          Namely, each machine has its own security code, which is linked to the serial number of the machine, through which you can enter the service menu and turn off the password.
          • otphas
            • Aug 2019
            • 127
            #35
            So, as i understood you start the machine without Nvram connected while pressing utility button and later connect Nvram under power, right ? Do you think it is not too risky , is it have any trick how to plug in Nvram under power ?
            • Zoran
              • 52
              #36
              That's exactly how I work.
              Otherwise, our whole life is risky.
              And these are just machines. A pile of iron and plastic to which we give our soul.
              Otherwise, I do these things like this because I have 30 years of work experience with electronics and a bunch of certificates for photocopiers, biochemical, hematological devices...3d scanners...ortopan...........
              I know how to clone nvram, change dials on ricoh .........
              I even have my own version of resetter for opc, developer, toner for Minolta office machines.
              More powerful and better than any version you might have seen on sale.
              • otphas
                • Aug 2019
                • 127
                #37
                We also using self made resetter for office machines and seems working fine too,
                • Zoran
                  • 52
                  #38
                  Complete procedure for resetting the CE password for C6000L and similar devices from the same series
                  • wjurls
                    • Feb 2017
                    • 501
                    #39
                    Do you know if this would work on a C14000?
                    • Synthohol
                      Certified Konica Expert
                      • 5894
                      #40
                      it confuses me why you risk electronic damage to a hundred thousand dollar machine when you can just reset the code in minutes with the help of our beloved Jotunn without the use of tools HERE
                      • jotunn
                        • 635
                        #41
                        Unfortunately CE password reset procedure doesn't work for production machines.
                        • Synthohol
                          • 5894
                          #42
                          • wjurls
                            • Feb 2017
                            • 501
                            #43
                            Just spit balling if you will. Tested the method on a retired pro 1100 we have here, which is around the same vintage. Did not work. I will contact Jotunn. Thanks. Forgot about his thread.
                            • tulintron
                              • Jul 2014
                              • 668
                              #44
                              As previously mentioned, I can do it with a quick command on the touch panel.
                              However, I charge a symbolic fee to teach.
                              • wjurls
                                • Feb 2017
                                • 501
                                #45
                                You are referring to production machines?
