654e jams with no jam code, forces reboot
  • 92DodgeDynasty
    • Jun 2022
    • 5
    Hello guys,
    I am hoping your brains and any good will my modest contribution has made can help me in my predicament.
    For starters, I am not a Konica tech, nonetheless I have a machine to service. I have the manual but no access to Knowledge Base, firmware or tech support.
    I have a 654e with frequent jams up the right side door. No crunching of paper & not always in the same place. What's odd is the jams are not being recorded in the Jam History section of the Service Mode. And after all the paper is cleared, I need to reboot the machine to get rid of the jam message on the screen. There are also no Trouble Codes recorded.
    I forced a tray jam by poorly loading paper and it does record those jams.
    I forced the door open during operation and it doesn't record those type of jams.
    So I am thinking I have an electrical issue, perhaps a door interlock switch. What leads me away from the door interlock is that I have to reboot the machine to clear the jam message. I'd think a flaky interlock would reset after a few good door closings.
    So that's that. If you need any more info I will try my best to provide it.
  • rrrohan
    • Sep 2011
    • 1977
    Re: 654e jams with no jam code, forces reboot
    any error codes at same time as jam?
    why do you need to reboot, does it not believe that the jam has been removed?
    • 92DodgeDynasty
      • Jun 2022
      • 5
      No jam or trouble code on the screen. Just a message to remove the jam, along with corresponding circled numbers to the jam location (10,11,14 etc). And no jam code gets logged into Jam History in Service Mode.
      The reason for reboot eludes me. I take out the paper, close the door but the same jam screen remains displayed. After reboot it's fine.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4710
        Is it happening from all paper trays? What happens if you print the internal test pages? What about paper path test in service mode?
        I would start by initializing the machine in service mode, and update firmware.
        • tmmdmmm
          • Apr 2021
          • 173
          Had something very similar, minus not being able to clear without a reboot.
          That duplex door is one of the few sensors that trigger an "open" state when its blocked. Duplex door sensor had some paper dust on it that would trigger a very quick "door open" message and stop the machine. Doors being open is one of the few jams that will not leave any code.
          It'll cause it regardless of tray, and regardless of whether or not the job is duplex.
          This sensor in particular is behind the panel just to the right of the duplex door if you are looking at it from the side. Believe its only two screws
          There's also the reflective sensor below the dust brush under registration, but that does leave jam codes. It however requires a reboot to temporarily fix
          I would go ahead and clean both sensors to start
          • allan
            RTFM!!
            • 5462
            If its not 1 then its 0. If a sensor of switch is faulty it can cause a X( voltage in the grey area between 0 and 5V) state. That can cause some issues the diagnostics cant deal with. It knows something is wrong but not sure what or where. Restart could make the X go back to 0 or 1.
            Next time that happens go to service mode under initialize and do an engine error clear, check if it clears the jam without having to restart.
            If it does then look to see if it recorded any error or jam.
            Check out sensor check and make the door switches and sensors to see if they work normally.
            Even check it when its in a jammed state. Could help you find the faulty input.
            Some inputs like fuser rotation and some others does switch from 0 to 1 while viewing the state.
            Whatever
              • 23008
              The machine has the ability to auto-clear certain error messages/codes without displaying them. Usually you see something like: "An internal error has occurred. The machine will automatically reset ..."
              It's especially common with errors like C2557 (developer density errors).
              There are two things that you can do:
              First to can disable auto-clearing of error messages (to see the messages): service mode > System2 > Internal Error Auto-Cancel > set Rank B to NO > set Rank C to NO.
              Second, you can print the Management List, which will display all the errors that occurred, regardless if they were displayed or not: Load Letter paper LEF to the top tray (older machines require Letter SEF) > service mode > List Output > Management List > Start
              The error list appears after pg 13 in the Management List, so this might not help you. Especially with C2557 codes the error can pop up every 6 pgs, so you never get to page 13. =^..^=
              • tsbservice
                Field tech
                • 8019
                Check in System 2 that machine is set to display jam codes, on this model I believe they are not displayed by default (thanks KM). That said I think jam codes still should be recorded in MML like BC said. Strange.
                Give us as much as possible information and you will be pleased with outcome ๐Ÿ™‚
                • tsbservice
                  Field tech
                  • 8019
                  Sometimes it will require not only to remove jammed paper but to open certain covers ie. bridge/relay unit of course if machine has finisher and so on. Reboot will reinitialize machine and you are ready to go.
                  • emujo2
                    • Mar 2017
                    • 1579
                    I'm dittoing the paper path sensor somewhere being dirty or faulty..The fault codes are captured in service mode regardless of how the machine is configured to recover or display them..There may also be some clues in the job log..deleted by user, deleted due to power cycle, I think it will even tell you if the door was opened during printing..The jam is not able to clear simply by removing the paper and only a power cycle will do the job..I don't remember if you said these were print, copy or both doing this. E
                    • 92DodgeDynasty
                      • Jun 2022
                      • 5
                      Thanks all, feel free to drop in any thoughts as they come to you.
                      I am going back, since I ordered the interlock switch. I will definitely check out the duplex door sensor and print out an MML.
                      It jams prints or copies, any cassette.
                      Here is just a photo of the screen and no corresponding jam code on the screen or in the history.
                      • allan
                        RTFM!!
                        • 5462
                        Does it jam single sided or only double sided? Does it always show the same locations even if you use tray 1, 2 or the bypass?
                        Does it pass any paper? What happens if you remove the paper dust cleaned and close the side door?
                        Whatever
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4710
                          Just for the record I haven't replaced an interlock switch in over 20 years so sorry to say I don't think that's your problem.
                          • tsbservice
                            Field tech
                            • 8019
                            +1 on that although I don't have your vast experience with KM, never had even to thought about changing interlock switch on KonMin office machine.
                            • allan
                              RTFM!!
                              • 5462
                              True and true. But i have had this kind of issue with finisher doors bridge doors and front doors opening while running.
                              Whatever
