Konica Minolta C364e Hangs at boot logo
  • Engr.Deen
    • Jun 2022
    • 5
    [Dead] Konica Minolta C364e Hangs at boot logo
    I was printing, when d office power go off and immediately go on and off again. D next morning i try to power On the Machine, it will just show the 1st logo and hang dea for about 2 to 3 mins, it will go off and restart its self. I try going in to trouble reset dsame not even going into d trouble reset just hang on d 1st logo. Pls any solution?
  • Woxner
    • Jul 2011
    • 853
    Re: Konica Minolta C364e Hangs at boot logo
    Reload firmware may have been corupted
    • tsbservice
      Field tech
      • 8053
      Replace SSD board.
      • Engr.Deen
        • Jun 2022
        • 5
        How can i reload the firmware, i can't even go into trouble reset menu
        • Engr.Deen
          • Jun 2022
          • 5
          Replace SSD board.
          i will try dis. Thanxs
          • copier tech
            • 8200
            You load the firmware onto a USB pen drive. You don't need to enter CE mode to update.
            There is a also a SSD update you could try that first before ordering a new SSD board.
            • techsxge
              • Jan 2022
              • 660
              I'd first start by removing everything not directly needed, e.g. Scanner Unit, Finisher, extra RAM Modules etc. Then try to boot. If this does not work, try to reinstall Firmware with the usual Procedure. Dont give up on the first try, some Machines will have you try 10-20 Times but eventually work. If you have a spare SSD Board, replace it.
              Worst Case would be to check the Power Supply after the first connector and check how much voltage comes through. If its less than 230V/110V, your Machines is pretty much death. But do not try to measure this if you dont know what you are doing as you can easily hurt yourself badly and in the worst event even kill yourself. Get someone who knows what they're doing for this or just replace the whole Machine
              • Engr.Deen
                • Jun 2022
                • 5
                pls i need d firmware, can u help me with it
                • Toxic
                  • 698
                  Could you explain this more, what first connector?
                  • Gumbke444
                    • Jun 2022
                    • 2
                    Nice list to know
                    • Konicatech
                      • Feb 2016
                      • 133
                      Most likely need a new SSD board, after fitting it update to the latest firmware.
                      • techsxge
                        • Jan 2022
                        • 660
                        The Power outlet and the connector where you plug in your cable.
                        • Oystercopy
                          • Oct 2009
                          • 623
                          Agree with others, replace SSD
                          OC
                          • diksiunix6624
                            • Jun 2022
                            • 3
                            1.Are you already replace the Power Supply Board ?
                            If already and same
                            2.can you access to service mode menu ?
                            If yes, you can check error code on the Counter->Service Call History (Data)
                            you can show the error code and you can search error code symthom on the service manual.
                            3.Upgarade the lates version firmware (use the thumdrive and plug on the USB port which close with plate) like Biz C360 procedure upgrade firmware
                            4.Replace the SSD Board/TPM Board if you have the part number : A5C1H02D15. don't forget to upgrade firmware.
                            hopely worked
