C-3851, not feeding from paper tray, code 12-01
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys.. I'm figuring out some of the issues with thing, but it seems, inherently, like this is a just a really lousy paper feed (lift) design in these trays. In fact, I had less issues with the older 3350/3850 than I do in these. I looked for a bulletin from KM, hoping to get some help, but no dice.
    Also, there appears to be a spring that was missing, on the paper jogger (pusher) that keeps the paper pushed to the feed roller when the tray is lifted... not sure what it was supposed to look like, but I think mine's broken.
    OC
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5827
    Re: C-3851, not feeding from paper tray, code 12-01
    Honestly I just put a 2"x1" slice of 3/8" thick foam behind the clear mylar to add support when the half empty tray lifts.
