Konica Minolta Error c-4725 C7000
  • MRJESSE
    • Jun 2017
    • 51
    Hi everyone.
    I usually work on Xerox Presses, so sorry for the silly questions.
    Just purchased a Konica Minolta Bizhub Pro C7000. Was working before it was moved to my address.
    Once it was delivered, it now has Error C-4725.
    I have swapped the K write unit with C and the error did not move.
    Should I purchase a new Image Processing Board?
    Or seeing it was just working, could it be my power/electricity?
    Any ideas?
  • MRJESSE
    • Jun 2017
    • 51
    Re: Konica Minolta Error c-4725 C7000
    Also is there a DIPSW I need to change?
    33-3 was set to 001
    • wjurls
      • Feb 2017
      • 498
      Image Processing Boards are pretty reliable. I would suspect the connectors where the write units plug into the IPB.
      Machines don't travel well and it's not uncommon for connectors to get jarred loose.
        • 23009
        The time I saw it, it turned out to be a loose connector on a board, like you say. =^..^=
