Konica bizhub C451 Firmware Error
  • bableprint@gmail.com
    • Jun 2022
    • 8
    Hi
    I successfully create c451-firmware write on SanDisk 128Mb using Firmware Imaging Toolkit Vesion 2, the problem is when i put it on the c451-MFP it say "Error. This is invalid Card. Plase make sure the Card." Any Help?
  • JasonSBE
    • Apr 2014
    • 186
    Re: Konica bizhub C451 Firmware Error
    Getting the CF cards set up properly is a massive pain in the butt. I'm sure someone else here knows more about it than I do but the starting question is what version of windows is on the PC which you are using the set up the card? You're going to want to be using Windows XP or possibly Windows 7. Anything newer than that is usually no good. Even if you use compatibility mode.
    • Synthohol
      Certified Konica Expert
      • 5849
      Man I haven't dealt with that in a decade.
      I used to use HxDen to write zeros to the drive first.
      If the cf card ever had a windows format ever it won't work unless you totally flush the drive and write zeros with HxDen.
      You may even need to use ftp to load the firmware if the cf card won't work even after cleaning it.
      HxD - Freeware Hex Editor and Disk Editor | mh-nexus
        • Jun 2022
        • 8
        I used both of XP and win with no seccess.
          • Jun 2022
          • 8
          Can you help me how to Write Zeros to the drive First with HxDen and what is Ftp to load?
          • Synthohol
            • 5849
            edit: added PDF
            • OPTION 1: Reformat using Windows
            The CF card can be reformatted in Windows. After reformatting it, DO NOT permit Windows to open the card. Windows will change the drive size, and it will no longer be usable for installing firmware on MFPs.
            IMPORTANT: This procedure does not apply to the CF card for the following models because the FAT16 file format is used: bizhub C200 or bizhub 200/250/350/222/282/362
            These models do not recognize FAT32 or any other format.
            • OPTION 2: Recover the CF card to Factory Default - No OS, No Data
            Use this option if Option 1 is not successful. For detailed step-by-step instructions, refer to the attached "Countermeasure for Formatted CF Card" document. This procedure uses a disk HEX editor (the attached HxDen.zip file) to remove the data that prevents the MFP from loading the firmware.
            CAUTION: This firmware has been used successfully in the the field; however, if the procedure is not followed completely, damage can result in the CF card, which may also damage the MFP. SSD and KMBS have no responsibility for the use or misuse of the procedure and the software that it references.
            Notes
            • JasonSBE
              • Apr 2014
              • 186
              FTP to load is done in service mode using Internet ISW. You have to set up a FTP server and then put the information into the MFP to pull a .tar file that you generate from the firmware. It's an involved process. I used to do it on the C650/C353 systems when we still had them in service because never had any appropriate CF cards. If you have a good card you should probably see if the Gurus here can help you get it set up correctly before you explore that option.
                • Jun 2022
                • 8
                edit: added PDF
                Notes
                Thank you Dear, I am working on it. I will let you know the result.
                • Albonline
                  • Sep 2008
                  • 1151
                  you can telnet into the copier, and use vxworks, embedded there. vxformat if i remember correctly. if you don't know how to telnet to copier, don't even ask.
                    • Jun 2022
                    • 8
                    I tried Countermeasure for formatted CF-cards very carefully and format it correctly but Still says Firmware Upade Error This is invalid Card. Any more thing to do Please?
                      • Jun 2022
                      • 8
                        • Jun 2022
                        • 8
                        edit: added PDF
                        Notes
                        • techsxge
                          • Jan 2022
                          • 660
                          edit: added PDF
                          Notes
                          This sounds to me as you could even use any modern windows and just format to FAT16 without registering a partition in windows
                          • techsxge
                            • Jan 2022
                            • 660
                            I never thought about telnet into the machines but heck yeah that would work i'm going to do something tomorrow
