Showing Jam But No Paper
+ More Options
Posts
  • CopyTech03
    • Jul 2020
    • 54
    [Jamming] Showing Jam But No Paper
    c451 has the O showing jam on the right side (the O is showing up on the screen between the lower front door and upper front door). The sensor by the paper dust collector is clean and working in test mode, the sensor on the door is also working properly. The only "sensor" showing up as a 1 in the jam screen is the OHP detection, but not sure if that's usually a 1 or not. Does anyone have any ideas which sensor could be causing this jam indication?
  • davidmtupper
    • Jul 2021
    • 326
    Re: Showing Jam But No Paper
    Is it showing the paper as late getting to the sensor? If so check the paper feed.
    • CopyTech03
      • Jul 2020
      • 54
      It just shows the jam but nothing there
      • zayonc
        • Jan 2022
        • 49
        turn on Jam Code Display Setting and look at the code
        • femaster
          • May 2011
          • 1506
          Jam codes would really help here. Below is all guesses because too much information is missing without the jam code.
          If it is a jam that won't clear at all, and you've tested the sensors as good, try to reboot. Those older machine, for whatever reason, sometimes get stuck in a jam state if they have been sitting with the jam for a length of time.
          If it clears, but comes back after it tries to feed again, then it's likely the paper is not making it out of tray, so check the feed unit in whatever tray it's feeding out of.
          • CopyTech03
            • Jul 2020
            • 54
            The last jam it had was a 1001 (bypass jam), but it was cleared and now still shows a jam in the middle or upper part of the machine/side door. The power has been turned off/on a few times bat never clears the jam indication.
            • Synthohol
              Certified Konica Expert
              • 5832
              IIRC that model has the paper dust guide below the steel reg roller.
              Dust will accumulate on it. Remove and clean throughly with an air can.
              If it thinks there is paper there (just dust) it will throw a false jam code.
              That's if it shows the jam at power on.
              If it happens when making a copy/print it's probably just worn rollers or one way clutch bearing slipping as no paper can leave the tray resulting in an 1101/2/3/4 jam depending on the tray selected.
              Good luck.
              Edit... you responded while I was typing.
              It's prolly paperdust like I said above.
              • JasonSBE
                • Apr 2014
                • 186
                Good luck.
                +1 to this. It's right below the image transfer roller on the door side. It's held in place with a plastic clip on one side, and 2 prongs on the other side. Could you take a picture of the screen or go into service mode and pull up the jam history?
                • Albonline
                  • Sep 2008
                  • 1151
                  You cycled the power but did you open the doors indicated ?
                  • femaster
                    • May 2011
                    • 1506
                    While you are in there checking the sensor under the reg rollers like other have suggested, I have another thought that and I hate to even bring up this with a machine of this age. Have you checked the sensor flag located on the metal shelf under the fuser? That assembly gets baked to death by the fuser and starts to stick. It also gets extremely brittle and breaks very easily. You need to remove the fuser in order to see it, but be warned, at this machines age, brittle might be an understatement...
                    I tried to find a picture for guidance, but I can't find a good one in the service manual, and I can't find the sensor flag in the parts book at all. I must blind. Maybe someone else might have better luck locating it.
                    • tmmdmmm
                      • Apr 2021
                      • 173
                      Good luck.
                      Yeah 451, 552. 654, 759, 808 All have these. I imagine its the issue. The problem is it won't show up as a jam code if its dirty enough to not go away.
                      • REGSIS
                        • May 2016
                        • 435
                        Enter sevice mode.
                        Select State "confirmation".
                        Select "Sensor check".
                        Sensors should be in "0" state, locate the one which is in "1" state.
                        Sensor might be dirty or faulty or its actator might be broken or stucked (didn't return to its original position).
                        Should be simple.
                        • zayonc
                          • Jan 2022
                          • 49
                          Re: Показывает Затор, Но Без Бумаги
                          for a knowledgeable person...
