Bizhub 501 developer dropping in drum unit
  • manzoorwighio
    • Dec 2019
    • 28
    Bizhub 501 developer dropping in drum unit . Toner is also dropping Developer unit to Drum unit so that developer unit empty
    after copy print is blacked and dropping on developer on paper
  • Albonline
    • Sep 2008
    • 1154
    Re: Bizhub 501 developer dropping in drum unit
    Originally posted by manzoorwighio
    Bizhub 501 developer dropping in drum unit . Toner is also dropping Developer unit to Drum unit so that developer empty
    high voltage issue. This usually happens when there is no charge. however it could be other hv loss problem.
    • manzoorwighio
      • Dec 2019
      • 28
      So how to solve it ?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4785
        Have you tried doing a PM with new developer, corona wires, drum? Replace or clean corona grid? Setup developer in service mode? Of course vacuum out all the dumped developer first. This is a very old model and required PM's to be done on time & correctly.
        • Albonline
          • Sep 2008
          • 1154
          Troubleshoot the high voltage system.
