CE Password Reset FYI
  • Ziggy
    • Feb 2018
    • 842
    on the bizhub 4050,bizhub 4750,bizhub C3350,bizhub C3850,bizhub C3850FS
    1. Select Administrator Setting
    2. Using the numeric keypad enter 12345678
    3. Select Security Settings
    4. Select Security Details
    5. Select Initialize
    5. Select Restore system
    6 Select OK
    7. The machine will automatically reboot.
    8. Select Menu - Touch Menu.
    9. Select counter - Touch [Counter].
    10. Select Keypad
    11. Using the numeric keypad enter Stop 00, Stop 01
    12. Enter CE password 92729272
    13. Press OK
    On other KM machiness see screenshot
  • techsxge
    • Jan 2022
    • 660
    Re: CE Password Reset FYI
    Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers.
    • adecanmin
      • Oct 2010
      • 322
      6 Select OK
      10. Select Keypad
      13. Press OK
      [ATTACH=CONFIG]54400[/ATTACH]
      Will this work on the c3851?
      • techsxge
        • Jan 2022
        • 660
        probably.
        • otphas
          • Aug 2019
          • 128
          If your Admin mode pass is also changed what is the procedure ?
          • Ziggy
            • Feb 2018
            • 842
            you can reset admin password in service mode . you can also just just unlock the admin lock out under enhanced security mode
            • Zoran
              • 53
              Maybe I can help you with my modest knowledge.
              The procedure is shown for the bizhub pro 951 and is the same for the c6000 c7000.
              You must be a skilled technician and confident in yourself, otherwise you will burn the machine.
              1. Remove the back cover of the machine.
              2. remove the plate shown in the picture.
              3.unload nvram
              4. with the parts thus removed, enter the service mode
              Hold down the bediener-zahler button and turn on the main switch
              5. when you have entered the service menu, carefully return the nvram to the bearings.
              6. press stop - 0 - C and turn off passford
              I can send you videos of me doing it
              This reset method keeps all settings, serial number of the machine and dials.
              Another way is to contact a Konica minolta service engineer who has access to the database.
              Namely, each machine has its own security code, which is linked to the serial number of the machine, through which you can enter the service menu and turn off the password.
