Bizhub C258, DF-629 random fail scanning format
  • LorenzoF
    • Sep 2022
    • 6
    Hi everyone,
    I'm Lorenzo and i'm new in this forum. I hope you can help to solve this strange behaviour on a KM C258.
    i have an issue with DF629 on a Bizhub C258.
    During scanning, where multiple A4 sheets are loaded (LEF), randomly one sheet stop for half a second then goes on.
    No errors, no jam, but that sheet is scanned as A3 format. (mixed size originals)
    All sensor cleaned. Repeated the initial set-up. And, at the end, replaced the adf unit with another DF-629.
    Issue is persisting. (For clarification, the original unit, installed on another Bizhub works well).
    I fear i have to look for the solution on the main body machine. Ideas?
    Thanks in advance.
    Lorenzo
  • Gift
    • Mar 2011
    • 2459
    Re: Bizhub C258, DF-629 random fail scanning format
    That's strange - did you relly clean all sensors and (even more important) all "dark holes" on the opposite sides of the reflection sensors?
    PS: Ciao!!!
    • tsbservice
      Field tech
      • 8022
      PS: Ciao!!!
      He changed DF and problem stays with the machine.
      Maybe Initialize all?
      • LorenzoF
        • Sep 2022
        • 6
        PS: Ciao!!!
        Thanks for your reply,
        reflective sensor on df-629 is clean,
        but not so clear what do you mean with "dark holes"
        • Madnhain
          • Dec 2012
          • 148
          Have you updated firmware? You'll get some strange issues if the FW of the DF isn't at the same level as the main engine.
          • Ziggy
            • Feb 2018
            • 784
            does it do this with all originals or just certain ones? are they using color paper when this happens?
            • Gift
              • Mar 2011
              • 2459
              Well the dark holes sit at the opposit side of the reflection sensors, it's usually just a square-ish hole and inside of it you might find a sticker made of black felt to eliminate unwanted reflections - if there's too much paper dust inside that area the sensor can cause false warnings/impulses. Might not be the problem if the issue wasn't reproduceable @ the other MFP you used for testing that feeder.
              • LorenzoF
                • Sep 2022
                • 6
                No update,
                the issue has occoured after a couple of years since installation.
                And after the replacement of adf, no more problem for a week, then it started again.
                Sorry... my mistake... the main body is a C308 not C258
                • LorenzoF
                  • Sep 2022
                  • 6
                  No, the customer uses common white A4 paper 80gr. and it happens with all originals (also blank sheets)
                  • Madnhain
                    • Dec 2012
                    • 148
                    Try swapping out the Scan Board, it's easy to get to and a pretty quick process. You should be able to swap it out with another machine (same model) without issue just for troubleshooting purposes.
