Why are my magenta prints Faded in one side? konica c360
  • Termi
    • Aug 2022
    • 12
    hello i am having konica c360, just installed new imaging unit due to corona charge grid spark in magenta, added new developer in magenta developing unit , but still there are patches in halftone test print in magenta, and when i print normally my prints are filled with magenta, can anybody help me with this issue . i am uploading attachments for better understanding. Previously after 50 copies my magenta toner used to peel of after printing
  • copyman
    Owner / Technician
    • Sep 2005
    • 4649
    Re: Why are my magenta prints Faded in one side? konica c360
    Still looks like developer is low.
    What are the levels under state confirmation in service mode. I suspect the magenta will be off.
    Aftermarket toner or drum? You can easily swap drum with another color to see if quality changes. This will eliminate drum.
    • Gift
      • Mar 2011
      • 2459
      Looks like everything is aftermarket^^
      • Termi
        • Aug 2022
        • 12
        Swapped the drum but same issues .. original toner original drum. TCR LEVEL STATE CONFIRMATION MAGENTA 4.50 CYAN 5 BLACK AND YELLOW 5.15. I AM THINKING THAT THIS MAYBE BECAUSE OF DEV UNIT . BCOZ AS I SAID PREVIOUSLY IN 50 COPIES MAGENTA TONER USED TO PEEL OFF FROM PRINT/COPY
        • Larhal
          • 566
          Magenta peeling off? Fuser
          Larhal
          If all else fails read the Service Manual!
          If that fails, meet me at the pub and we will discuss it.
          • Albonline
            • Sep 2008
            • 1145
            That would have been your mag developer peeling. (fuser not hot enough to melt iron) if it was ending up on your paper, the belt cleaning system took a whole lot of it.
            • Termi
              • Aug 2022
              • 12
              So what should i do?? Change developer unit or fuser bcoz rest all cyan black yellow are properly printed . I have only problem with magenta .. almost 6 developers replaced in magenta
              • Termi
                • Aug 2022
                • 12
                Why so??
                • Albonline
                  • Sep 2008
                  • 1145
                  if its going through new km factory units I would be looking into toner density levels. if you are simply reloading your old developer units i would try a new km unit. this line of mfps was noted for consumable life overrun tolerance ,that being said they only go so far.
                  • L0rdC
                    • Feb 2021
                    • 82
                    development unit M is new or rebuilt? if it's rebuilt, remember to reset the unit, try swapping the M drum for the Y, other than that, it seems the developers aren't right, those TCR levels aren't stable
                    • Gift
                      • Mar 2011
                      • 2459
                      Why so??
                      Just reading the hints like "just added new developer into dev unit"
                      • Termi
                        • Aug 2022
                        • 12
                        yess i added developer to new dev unit bcoz magenta developer finished very soon .. the only problem i am having is in magenta . rest everything works fine . thanks for helping . i am just new to the industry need to learn many things
                        • Gift
                          • Mar 2011
                          • 2459
                          Perhaps the magenta dev unit is faulty or that developer you're using is bad quality.
                          Usually you should swap the entire dev unit and not replace the powder - I know this can work well but that's not guaranteed.
                          As the others said it's also important to chip the unit.
                          Plan b might b using a BK dev unit and convert it to color, haven't done it with that series though.
                          • Albonline
                            • Sep 2008
                            • 1145
                            As i said b4 get a genuine konica developer unit. install it according to the service manual instructions, doing all suggested adjustments. then monitor the toner level history. the hopper may be damaged or high voltage board not up to snuff , i have seen piles of toner short out the hv system. also if the mad oiler worked on this unit i would be looking for paths to ground for the cyan bias .
