Bizhub C283 Jamming
  • copierjeffstl
    • Oct 2017
    • 18
    Bizhub C283 Jamming
    I don't have the jam code, but machine jams intermittently after anywhere between 10 and 100 pages right past registration sensor. It will have about inch of print on it.
    Probably a clutch causing this. I just don't know which one(s). Thinking the clutches on the feed rollers and or feed assembly clutch. They only use upper paper drawer.
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C283 Jamming
    Go back and get the jam code. Its probably J3003. Then that would be the registration clutch, bushings and probably the rollers on the sincro unit.
    Meter reading on the machine?
    Whatever
    • copierjeffstl
      • Oct 2017
      • 18
      I'll try and code tomorrow. Thanks.
      • allan
        RTFM!!
        • 5462
        These machines are super easy and predictable. If the machine is over 500K those registration bushings and rollers are causing the clutch to fail. Take a clutch and at least some bushings with you. Feed rollers, feed clutches and a spare relay clutch for J2002 would not be good for the ride as well. I carry them as boot stock.
        Whatever
        • otphas
          • Aug 2019
          • 127
          Do you mean C284 ?
          • tmmdmmm
            • Apr 2021
            • 173
            Second this. J9901 and 3003 are usually reg bushings and clutch on these models and occur more frequently out of Tray 1. Other trays usually have enough force carrying it by the time it reaches registration that it doesn't jam.
            4 Bushings and clutch are available from KM as of a month ago, last time I ordered
            • allan
              RTFM!!
              • 5462
              Originally posted by otphas
              Do you mean C284 ?
              Ooooo I missed that bit my eye only caught the 283 bit. If its a C284 scrap the advice.
              Whatever
              • copierjeffstl
                • Oct 2017
                • 18
                Sorry. It's a 283. B & W machine.
                • allan
                  RTFM!!
                  • 5462
                  Ok still on the right course.
                  Whatever
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4785
                    If 150k or less on meter I always just spray the reg clutch with electronic cleaner and then canned air. With clutch on machine, no need to remove. Lube the reg roller bushings and should be good to go. Never had to replace clutch but maybe one time.
                    • Ziggy
                      • Feb 2018
                      • 810
                      depending on copy count the registration flag could be worn down causing the jam
