1051 Putting lines on second side only
  • cmitch
    • 53
    As title suggests, when printing one side, the print is clean as a pin. When duplexing, lines appear at bottom of page (operator's side) in white area (see pics). When first seeing it, knee jerk conclusion was drum. But seeing it isn't marking on first side, it looks that it has to be something else. This is the first time I've encountered this oddity. Thoughts?
  • cmitch
    • 53
    Re: 1051 Putting lines on second side only
    Update:
    The drum looks like hammered feces. Ruffles have ridges and so does the drum. 603,000 copies. I will replace drum when new one gets here before I go any further. We just ran 400 copies and lines now appear on both sides.
    • tsbservice
      Field tech
      • 8008
      Yes lines look like worn drum.
      • allan
        RTFM!!
        • 5462
        Replace the discharge wire and the drum cleaning brush to extend the drum life to avoid that.
        Whatever
        • cmitch
          • 53
          Discharge wire no doubt needs replacing. However, cleaning brush was replaced 200,000 copies ago.
          • Ziggy
            • Feb 2018
            • 724
            make sure the transfer cleaning brush gears aren't stripped, if they are good look at the condition of the transfer belt cleaning brushes and the transfer belt too.
            • wjurls
              • Feb 2017
              • 496
              Also check the drive coupler and grounded bearing that drives the cleaning roller. It will wear down and cause excessive play and lack of ground to cleaning brush.
              A4EUR70F00 Cleaning Gear /2 Assy
              A0G6531500 Cleaning Bearing
