help me serial number needs to be entered contact your service representative
  • filladefilla
    • Apr 2024
    • 46
    #16
    Even as I speak, know I can't enter into service mode... because Stop 00, stop 01 can enter into service mode....
    • Synthohol
      Certified Konica Expert
      • 5901
      #17
      i would suggest booting with a firmware stick and select machine/type and check/enter the appropriate digits if "FF" is displayed.
      if there are correct digits there.
      the scanner serial# is on a label under one of the scanner covers should you need to enter it.
      let me know if you verified that because it seems the machine has had a lobotomy and that info gets boinc'd too.
      is the meter wiped?
      • tsbservice
        Field tech
        • 8061
        #18
        Originally posted by filladefilla
        I'm having this same issue and my Konica Minolta c454e is sitting for days and don't know what to do to it.
        Replace battery on main board.
        • filladefilla
          • Apr 2024
          • 46
          #19
          Battery is replaced and I'm getting these errors.
          • filladefilla
            • Apr 2024
            • 46
            #20
            • tsbservice
              Field tech
              • 8061
              #21
              Try this procedure.
              Originally posted by ivovb
              Re: C454e "TPM chip has been changed"
              Here is some update on my case. First of all many thanks to Gergo. Secondly Yes it is not needed to order any spare parts from KM, just 3 euro aftermarket battery 3V 2477. It is obviously that KM battery with 57 marking are bad eggs.
              1. Change the battery.
              2. Use reset tool for MFP board 3 times successively. (Next time I'll try only once ...)
              3. Update firmware to the latest one - GDL. Check beforehand machine/type. In my case they were ok. GHV not needed.
              4. Go to service mode and check SW 10 - it was generic machine in my case. Check also Marketing area in System 1 - it was US not EU...
              5. Set serial numbers in service mode - printer, scanner and for any option.
              6. Activate HDD and download movie data.
              7. Do initial installation because it is new machine...
              8. Do any user setups - network, scan destinations etc.
              Concerning #3 - GHV in my opinion must give a chance to change battery without settings lost. So #4-8 not needed. Need a proof.
              Concerning #7 - Stop-1-1-4-4-C the year is 2007. Could not made it 2020. In Admin mode it is possible to set it right.
              Machine has full functionality so far.
              Hope my procedure is most complete and usefull.
              BR
              • JMS
                • Apr 2023
                • 30
                #22
                When you update firmware, the difference between firmware on mfp and latest firmware should not be to big. We use Firmware G20-M1 first (when the firmware on mfp is lower than that) and then the latest firmware. Once we forgot it we had the TPM-Error.
                • filladefilla
                  • Apr 2024
                  • 46
                  #23
                  if I understand you well, I have to install G20-M1 first, after that then I install the latest firmware.
                  • Synthohol
                    • 5901
                    #24
                    there really is no need to go past g20 m1 unless there are specific issues to address or an accessory that requires it.
                    or you just have a compulsive need to have the latest installed because its the latest
                    i dont remember if the GDB SMB enhancements below went into g20M1?
                    can anyone confirm for my own knowledge?
                    Re: Minolta firmware C284-284 compatibility
                    GDB-M1 firmware with bit sw 219 will lock in smb 2.0.
                    hex 04 will lock in smb 2.0 as the default.
                    3
                    Konica Minolta
                    SMB v2/v3 Support
                    KONICA MINOLTA
                    SMB v2.0 support
                    SMB v2.0 was introduced to IT5 series (e.g. C258) beginning of 2016 with
                    function version 2.1
                    For following IT4 models a special firmware was released in August 2017 to
                    support SMB v2.0:
                    DLBT1708055EN: bizhub C754e/C654e
                    DLBT1708056EN: bizhub 754e/654e
                    DLBT1708057EN: bizhub 554e/454e/364e/284e/224e
                    DLBT1708058EN: bizhub C364e/C284e/C224e
                    DLBT1708059EN: bizhub C554e/C454e
                    DLBT1708060EN: bizhub C754/C654/C554/C454/C364/C284/C224/
                    bizhub 754/654
                    For IT4 devices, DipSW 219 can be used to select available SMB version for client
                    function.
                    DipSW 219
                    bit 2 enabled (set to 1): only SMB2.0 is supported
                    bit 4 enabled (set to 1): only SMB1.0 is supported
                    both bits are disabled (set to 0), SMB1.0 and SMB2.0 are supported
                    both bits are enabled (set to 1), only SMB2.0 is supported
                    HEX bit Setting
                    0x00 ###0#0## SMB1.0 and SMB2.0
                    0x04 ###0#1## only SMB2.0
                    0x10 ###1#0## only SMB1.0
                    0x14 ###1#1## on
