help me serial number needs to be entered contact your service representative
  • Xnabilos
    • Oct 2022
    • 5
    [Error Code] help me serial number needs to be entered contact your service representative
    Hello, I encountered this problem, please help konica minolta bizhub C554e ( serial number needs to be entered contact your service representative ) When I lit it, it gives me this message, the serial number. I changed the memory battery. It was expired. Is there any help how to enter this number, knowing that the programs on the screen do not work and the serial number is written on the copier? I want the input method or the C554e Bizhub firmware link. Thank you
  • Ziggy
    • Feb 2018
    • 802
    Re: help me serial number needs to be entered contact your service representative
    Enter service mode the look under sysytem 1
    • Xnabilos
      • Oct 2022
      • 5
      Thank you, brother. I entered the settings and found these boxes. Where do I enter the serial number? Do I enter it in all the boxes or only one? Thank you
      • tulintron
        • Jul 2014
        • 668
        You must enter the serial number only in the PRINTER field. However, if you are not a technician, there will be other steps to follow that need knowledge. I advise you to call a technician and have your machine back.
        • Xnabilos
          • Oct 2022
          • 5
          Thank you for the reply. I did not find a suitable technician for my problem, because I am in a place far from them, so I raise my problem in the forum. I entered the serial number in the printer field and it gave me this message, but the first message no longer shows the message of the serial number. Thank you
          • techsxge
            • Jan 2022
            • 660
            If you can find a competent technician, he knows how to help you from afar. No need to come on site for this...
            • emujo2
              • Mar 2017
              • 1579
              once the battery died you opened a floodgate..I've seen this require the replacement of the majority of consumables..It's too late now, but there was a firmware released that changes where the NVRAM info is stored so that a dead battery does not result in this. You will have to replace the drum or check to see if the PPLM modifications may have been reset back to factory defaults as well. If you have any more of these e series I would do everything possible to get this firmware and add it to your devices. E
              • adecanmin
                • Oct 2010
                • 321
                I've got a lot of these e machines. Do you have a date when this firmware came out? The newest base firmware I have is from a year ago.
                • Xnabilos
                  • Oct 2022
                  • 5
                  Thank you brother for the reply. Yes, I want to help you get this copier back to work. Thank you very much for the initial help
                  • Woxner
                    • Jul 2011
                    • 854
                    To get rid of drum warning just go to setvice mode. Hit stop 0 c. There you will find life warning just see all to off. Might be stop 9 c. Eithet way its there. I just did this.
                    • emujo2
                      • Mar 2017
                      • 1579
                      GHV-M1 released in 2019
                      2.2.1 Fixed issues
                      The following issues are solved in this firmware.
                      1. After turning OFF/ON the Main Power, the entry screen of serial number may be displayed in English and the MFP may not start. (ERBJTG1800912351 and others).
                      • Xnabilos
                        • Oct 2022
                        • 5
                        Hello brothers, I have changed drum unit and the message is still there, knowing that I deleted it from the settings. Please, do you have a full flash bizhub C554e that passes the USB to bring it back to its original mind, send me the download link, and thank you very much for helping me solve the problem
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2139
                          I just had this issue on a remote island e series machine, the battery was flat and it also corrupted the SSD. I would advise replacing both if the battery is flat / leaking using the "at the same time" special procedure. Meter reading will be reset to 0 doing this and the machine will need to be setup again using the original out of box instructions to clear the lines of shame security feature.
                          • Copier repairman
                            • Aug 2019
                            • 86
                            I feel like I want to run right away.
                            Contact your nearest Minolta technician.
                            Mishandling may result in irreversible damage.
                            • filladefilla
                              • Apr 2024
                              • 46
                              I'm having this same issue and my Konica Minolta c454e is sitting for days and don't know what to do to it.
