BH-C-280, manual feed lift table
  • Hansoon
    • Sep 2007
    • 3374
    In all the years these BH-C-280/360 series being around, I never had an issue with the manual feed table lifting. Now I have one where the table goes up and immediately falls back into the down position. Could imagine a sticky patch in SD1 responsible for this.
    According to the manual, I have to remove the right vertical door, (yikes.....) to come to the solenoid SD1 and cam thingy. Do you guys have a workaround to make the procedure easier and less troublesome, please?
    Hans
  • techsxge
    • Jan 2022
    • 660
    Re: BH-C-280, manual feed lift table
    Sounds more like the motor is too weak or the gears are broken?
    Does it work normally if you help it lifting up and hold it until the motor moves it down again?
    • Hansoon
      • Sep 2007
      • 3374
      Good question. Didn't try that yet, but sometimes it works without a problem. Most of the time, the customer put only one sheet on the manual feed table. When I tried it with the test mode, having 50 sheets on it, it worked flawless.
      Got from the beginning here that "Sticky Patch" feeling........
      Hans
        • 22999
        The only thing that I've seen is the post at the front or rear breaking on that lift plate. =^..^=
        • techsxge
          • Jan 2022
          • 660
          Either we have the same customer or this is one of the biggest coincidences so far becuase i got a call an hour ago:
          Same Machine, same problem. Like actually the same. Sporadic manual feed lifting problems.
          Customer reported abnormal noise, but its quiet so not too sure if its normal and he never heard it or if it might be a dying motor rn
          • tsbservice
            Field tech
            • 7979
            Hans, what is jam code, please?
            here is some Youtube video:
            Konica Minolta C280 service bypass unit solenoid - YouTube
            • Hansoon
              • Sep 2007
              • 3374
              Thanks! That's exactly I was afraid of........
              The guy has more trouble cutting a new patch than removing that whole door itself, LOL
              But I'm grateful, seeing this.
              Hans
              • femaster
                • May 2011
                • 1482
                Hans
                Was going to say, I just removed a C360 door for the first time a couple weeks ago, and it really wasn't all that hard to get off. I was expecting it to be a lot worse than it was.
                • techsxge
                  • Jan 2022
                  • 660
                  Hans, if your customer called today that the problem went away i have to say that we must have the same customer... Although we live and work at the other side of the country...
                  Fixed my customer byreplacing the gears doing the lifting
