Hide counter button on Bizhub 8 Series
    • 16464
    #16
    Re: Hide counter button on Bizhub 8 Series
    Originally posted by Konicatech
    Hi
    Yes only looking to see if it's possible to hide the counter button as I was asked by end user if this was possible and it makes no difference to us as a supplier anyway as we obtain readings remotely.
    There is no hidden agenda, and makes no difference to us if there's is or is not a counter button on the display ๐Ÿ˜‰
    I'm not really buying your explanation but I guess anything is possible. You should have told them no from the beginning. End of story.
    • tsbservice
      Field tech
      • 8043
      #17
      True that. Plus it really cannot be hidden as far as I know.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4752
        #18
        I believe the OP. I've had crazier requests from customer's. Now if they were asking how to change the counter that's a different story....
        It looks like the customer wants a simple screen. Should be able to get just copy & scan on the screen but small counter tab will always be on top. It's so small and hardly noticeable.
        • Synthohol
          Certified Konica Expert
          • 5885
          #19
          the craziest request i have had in a decade is he wanted me to show him how to do 2 sided OHP so he only needs half as much.
          i just stared at him for an uncomfortable amount of time like a deer in headlights and then it hit him why that may not be ideal.
          also, just set the screen to copy or scan by default instead of main menu.
          out of sight out of mind.
          • techsxge
            • Jan 2022
            • 660
            #20
            I have had a lot of stupid request already...
            And the morw you think into it, the more you understand it even though you know they're stupid as fuck
              • 23010
              #21
              I had a Lexmark customer once ... it was a $1999 special. The salesman did not want to be bothered with delivering it, so I got the pleasure. After setting up the driver & scanning, I did a demo. She wanted to know what every button did, in detail.
              Now I've worked on a lot of machines over the years, but I think that you can understand that, there is no way to know every feature on every model of 8 brands of equipment. When I did not have satisfactory explanations of some of the buttons, she tells me she wants this button moved over here, that button moved over there, this one smaller, this one larger, this one gone ...
              Naturally Lexmark writes unique firmware for enterprise customers, but it's certainly not anything that I can do, and certainly not for free on a $2K machine. Her response was that her husband writes firmware, and he does this all the time. He should have no problem doing it on the Lexmark then. =^..^=
              • Sysco
                • Mar 2010
                • 43
                #22
                Use a duck tape to hide the counter button on the screen.
                Stupid user request make stupid resort.
