BizHub C450i settings
  • copyman
    Owner / Technician
    • Sep 2005
    • 4757
    This is the first C450i I've sold and have some issues with changing the factory settings. Different look from 4 & 8 series.
    1) How can the default announcement screen be turned off?
    2) It won't allow PDF compact and Black and White to be selected at same time so it can be default for scanning. This was default on their old C454.
    3) Can this model be set to wake up when you walk up to it like the 4 series?
    Thanks in advance for any help.
  • rrrohan
    • Sep 2011
    • 1977
    Re: BizHub C450i settings
    do you mean the market place screen saver? If so just turn off marketplace
    strange, i just looked on a C754e and it wont let me set that nor will a C250i
    You could just set default to standard PDF. File size should still be small considering its only 2 colours of data
    i just tried Bird Demo page
    Compact PDF Greyscale = 214KB
    Compact PDF Colour = 250KB
    standard PDF Black/White= 3MB
    where was that feature on the 4 series? I know it did it but never knew how
    • tsbservice
      Field tech
      • 8051
      Admin > Security > Quick security settings > turn off IP filtering and turn off Display security warning
      Also under Network select IWS and turn off Marketplace.
      And lastly.
      • [Utility]
        • [Administrator]
          • [Maintenance]
            • [Timer Setting]
              • [Power Settings]
            • [Awake from Power Save Mode by Touching Control Panel] When recovering the machine from Power Save mode when a user moves closer to the Touch Panel, set this option to ON (default: ON).
      • Ziggy
        • Feb 2018
        • 801
        To totally turn off Market Place.
        In service mode system 2 software switch settings Set sw 172 to hex 01. In admin mode-,network- IWS setting- market place setting turn it off. Admin -system- main menu default (classic style) - highlight market place - edit- under function name set it to not set.
        • rrrohan
          • Sep 2011
          • 1977
          You know marketplace and the new U.I was a flop when even KM runup guide tells you how to turn it off and default back to classic interface
